I have a triton le keyboard. i have three keys that are not sounding when pressed
You probably need to clean the contacts underneath those keys that are not sounding, otherwise check the components (diodes, resistors, etc..?) that are connected to those contacts , also check the wires and/or the connector that goes from the contact plate to the main board, see if there are broken wires and resolder, check if the connector pins are dirty or badly soldered and clean/resolder if necessary.
if all of the above fails then It is not a bad thing to check other connectors too, also any ICs that are plugged into sockets as there may be some oxydation so cleaning the connectors and unplugging and reinstalling the ICs could help somewhat.
Hope you can fix it.
regards
Triarcuate
