Cameras Logo
Ryan Randazzo Posted on Nov 27, 2017
Wiring pinout needed!!
I have a samsung snv-7080 network camera which has had the connections cut and im now left withe bare wires. I need to know whay the RJ45 pinout is and which wire goes to which pin. I have about 12 wires in 6 twisted pairs. Yellow/Green, Blue/Purple, Red/Black, Orange/Brown, Grey/White, Cyan/Light Blue. Thanks in advanced.
5 Related Answers
Anonymous
  • 11896 Answers
  • Posted on Jan 17, 2009
SOURCE: 1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Anonymous
  • 101 Answers
  • Posted on Aug 26, 2009
SOURCE: ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
saailer
David Burbee
  • 1871 Answers
  • Posted on May 30, 2010
SOURCE: colour codes for 83 corona, wiring stereo the
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Anonymous
  • 2299 Answers
  • Posted on Nov 15, 2010
SOURCE: I have a 2002 ford
This is the factory stereo colors
Radio Constant 12V+ Wire: Orange/Black (Thick Wire)
Radio Switched 12V+ Wire: Yellow/Green
Radio Ground Wire: Black/Yellow and Black/Green
Radio Illumination Wire: Orange/Black (Thin Wire)
Left Front Speaker Wire (+): White/Black
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): White/Purple
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): White
Right Rear Speaker Wire (-): Gray
Anonymous
  • 635 Answers
  • Posted on Apr 02, 2011
SOURCE: i have a wiring kit
The JVC wiring kit has more cables than the original radio plug. The original car radio has just basic functions, but the JVC has advanced functions . It would have been helpful if you had given the model # of the JVC stereo.
First things first . Connect all the matched colored pairs together eg:- White / Whiteblack , Grey / Greyblack ,Purple / Purpleblack and Green / Greenblack . These are speaker wires .
Next Yellow & Yellow , Black & Black. These are the battery + and Ground ( -). Next connect the Pink and Red wires. This is the accessory connection ( the stereo will play only if the key is inserted )
Rest of the wires you can ignore. For eg: the blue wire is for powered antenna, brown for alarm etc. All these functions your car does not seem to support. Now if the system still does not work , you could have damaged it due to a mix up in the connection. Please make a note of how you had connected the system before my suggestion so we can trace the fault. Good luck.Revert back for further assistance .
2009 Hyundai Santa Fe. I need dash harness colour codes please?
Edited the first part for clarity.
Hyundai Santa Fe SE 2009 - SYSTEM WIRING DIAGRAMS
https://portal-diagnostov.com > 2020/03/26 > radio-hyu...
Mar 26, 2020 - RADIO - Hyundai Santa Fe SE 2009 - SYSTEM WIRING DIAGRAMS Radio Wiring Diagram, with Amplifier & Rear Seat Entertainment (1 of 2).
Hyundai Santa Fe (2006-2012) EMP300RDS pinout
https://pinoutguide.com > ... > Hyundai Santa Fe pinouts
Dec 10, 2019 - Hyundai Santa Fe (2006-2012) EMP300RDS pinout ... Audio Head units > Hyundai Santa Fe pinouts · 24 pin Hyundai Head Unit connector layout
2009 Hyundai Santa Fe Radio Wiring Harnesses - Crutchfield
https://www.crutchfield.ca > ISEO-rgbtcspd > ymm > 2...
Need a radio wiring harness for your 2009 Hyundai Santa Fe? Get free shipping and free lifetime tech support with your order.
A client gave me this simply as a means to run my computer itunes through, so it comes out the ceiling speakers. I am not tech savvy at all, and im looking at the wall plug, 2 of them side by side with 8...
The screw section is probably for the house speakers. ( if they are still on the other end of those screw's wiring.) If you have a working speaker on your computer you need a jumper wire or sorts. Buy, build, or make it by cutting one your speaker wires a couple feet behind the speaker and stripping an inch of insulation to get to the bare wire.
Get some music on the speaker you use for testing. Cut the wire and remove an inch insulation from from the cut end coming from the computer. (you test and learn how to do this - hook it back up to the speaker wire. See if you made work again.)NOW THEN! Take the jumper wire ( there are at least two.) and start touching it to any of those two screws. If your computer was and still playing music after you cut the speaker wire or inserted a test plug with speaker wire - you will be able to locate speakers connected to that site.
This p in to that live speaker output has a lead out with 2-3 bare wires on the end to connect to the on the on the other end have the two pieces of wire with a speaker disconnected. to touch to those
2answers
Where would I find the wiring diagram for a Samsung Security Camera SOC-a101? It is a 6 prong plug and I need to connect a PS2 connector to it.
I have a Samsung soc-a101 digital color security camera, wires corroded off male plug to camera what is the wiring sequence to the plug? wires are: red 12 volt looking at pin's front side not back of plug, from plastic tab pointed up red is on right top terminal, audio is top left terminal which I assume is white wire, then I have a clear plastic covered wire and the bare stranded wire. what terminals go to these wires I assume the bare wire goes to the metal ring of the plug as it had a wire soldered to it just don't know which! this leaves the bottom pins on the left and right set of two and the two bottom pins! Can you help? remember I am looking at the front not back where the wires are soldered. Thanks.
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
1helpful
2answers
I need a wiring diagram for soc-n120 camera
1 2 3 4 5 6 Green Red Yellow Bare Gorund Clear
Cover
Black RJ11e color & slot. Orientation Lock Pin Down. Wire at bottom
1helpful
2answers
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 • Cameras
3helpful
2answers
I need a wiring diagram for rj-11e.
rj11e pin lay out with turned over. brass pin facing you.release
pin to the bottom. 1 left to right to 6.
1 2 3 4 5 6
bk---red--green--yellow--clear (bare ground)--
that is it.
Need wiring map for RJ11 conector for Samsung SOD-14C camera
Well good news and bad news if u just got shot ends easy cut end off and copy other end with new rj11 6 pin phone jack.. what im trying to do is give camera secondary 12v power and use the wire in the jack to splice into RCA type connector to work with my old dvr
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
