My air compressor turns on and off at very little interval. example: will start using air gun, it will turn on and off at almost every shot. much starting up and stopping. Help
This can depend on many variables . (1) How big the air tank of the compressor is, (2) how many PSI the compressor is set to hold, and (3) how many PSI your air gun uses per shot. If you gun is rated at a very high PSI and your compressor has a small tank and low PSI, you may want to consider investing in a larger tank.
I had a similar problem with my air compressors in Boise Idaho but the tank's PSI was compatible with the gun's PSI. Any ideas on what was the matter there?
