SOURCE: heater temperature control buttons
The board is bad. The part number is IDXLCPA1930. Expect about a $400 replacement cost.
SOURCE: Drain gas heater for winter
On the side of the heater, you will see the water connections. Directly underneath them, on that black component that they attach to, there is a drain plug of some description. It may be a draincock, or just a plug. In either case, simply open or remove it to safely drain your heater. In a pinch, you could also disconnect the water connections at those unions (the big grey connectors), but they can be fussy to reassemble, and you run the risk of losing the o-rings.
SOURCE: Hayward H250 pool heater lights
if it is an electronic model you prob have a dirty flame sensor
SOURCE: Hayward H250K gas pool heater error code
Low Flow errors are not necessarily real. They can be caused by improper adjustment or a defect of the pressure switch. Locate the pressure switch. Verify that the "switch" makes contact. Adjust the dial, reducing the distance the switch has to travel to engage. This will effectively lower the operating pressure required to operate. Keep adjusting until the unit stays on.
