Tried every number that I could remember.
Zenith TV unlock [Child lock]
Tune the
television to a channel blocked by a child lock. The words "Enter Lock
Code" will appear on the screen with four dashes underneath
Press
the numbers on the remote control to enter the child lock pass code to unlock
your Zenith television. When the code is entered correctly, the blocked channel
becomes visible. The words "Enter Lock Code" remain on the screen if
the password is not correct
Enter "0000" if you did not
change the password on the television prior to enabling the child lock feature.
This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the
television but no longer remember the code. This number allows you to bypass
the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access
the "Main Menu" screen on the television.
Scroll
to "Special" using the up or down arrow buttons and press the right
arrow button to access the "Special" sub-menu.
Push
the up or down arrow button to highlight "Key Lock" and then press
the right arrow button.
Press
the up or down arrow button to change "Key Lock" to "No"
and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
SOURCE: Parental Control Lock
I'm really guessing here - -but while you're in the parental controls screen I believe you can use 0-0-0-0 as a backdoor key. It's different for every manufacturer, Philips uses 0-7-1-1 example. But the users's manual for that TV says that the "default" is 0-0-0-0.. Don't really understand their use of that terminology so it's merely a guess... But here's something I am really sure of;;; The owner's manual can be downloaded for free at the Vizio web site: http://www.vizio.com/support/downloads/ and their support line is: 1-888-849-4623 or you can email tech support at: [email protected] Hope this helps. Good Luck Bill
SOURCE: Reset Parental Control
Press and hold both VOL- on the TV and 0 on the
remote control simulaneously for a few seconds
until the LOCK menu appears on the screen and
then the password should be cleared.
SOURCE: Forgot the Parental Control code for a Sharp 32u - s600
CLICK HERE for your manual
page 15 starts the V-Chip instructions
Page 22 gives instructions for re-setting if you forgot the password.
Thanks for using FixYa - a FixYa rating is appreciated!!
