I have 2 craftsman mowers. older ones. one is a 15.5 HP turbo cooled 42 inch 6 speed. the other one is a hydro 4000 kohler OHV 14HP 42 inch.
can I put the 15.5 HP turbo cooled engine on the hydrostatic mower?
www.sears.com/craftsman-replacement-belt...42.../p-07133153000..
Sears
Rating: 3.5 - 42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
there are many variables, since you didn't give any specifics. if it is an older, single cylinder, L-head engine, labor would be roughly 1/2 hour; if an older twin, L-head, about 1 hour; if it's a kohler, add about 1/2 hour; if it's a single, OHV, about 1 hour; if a twin OHV, 1 1/2 hours; if a kohler, add 1/2 hour. each shop has it's own labor rate. flat rate manuals will vary and are not realistic when dealing with old, possibly rusted or frozen bolts, which will increase the cost of repair. a new head gasket will usually cost between $5 to $30, depending on which engine you have. {some older craftsmans had a briggs laid sideways or an onan. these will require a lot more work and the labor would be higher]
if you go to sears.com click on parts direct
enter your mod # and to the right of the next page says get manual click on that and then click on view manual and it should come up for your mower
Is this a Kohler engine? If so there is a wire going to the coil from a 2 wire harness located at rear of engine near spark module. Unplug this wire to determine if problem is coil or a safety switch.
