Question about SMC Computers & Internet
Cant seem to change my poassword,,,help please
How do i cahhange m,y password,,,i have the smc log in page and it wont accept my username and password
Posted by Art Thompson on
5 Related Answers
Anonymous
  • 556 Answers
SOURCE: i cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Posted on Dec 06, 2007
Anonymous
  • 139 Answers
SOURCE: I need to change my password and username!!
After you log into the router, from the main screen, click on "Management" > "Access Control" > "Passwords". You can enter a new password here.
More details are available on page 86 in this manual on the Zhone web site.
Good luck...and I hope this is helpful!
Posted on Jan 14, 2008
Anonymous
  • 16 Answers
SOURCE: cant login to router
When in doubt double check your work. You held the reset button down on the back of the router for long enough for the lights to go out then start blinking again? Then you went to 192.168.100.1 in your browser and tried admin for your login name and motorola for your password? If you did all of that and it's still won't accept your login try to power the router off for at least a minute by pulling the power cord and make sure you clear your browser cache before trying to access the default gateway address in your browser again.
Hope that helps!
Jill
Posted on Nov 30, 2008
Anonymous
  • 611 Answers
SOURCE: ZYXEL p-660 configuration for BSNL
in there you just give the dyanamic ip address automatically then you get it but you want to give it the go for the router mode in that you get it i just send a link you just download that think user giude then go througt it step by step ok
zyxel.com in that ftp server is there go througt it
Posted on May 05, 2009
John P Griffin
  • 89 Answers
SOURCE: i cant log into the admin account on 192.168.1.1
press the RESET button on the back of the router and hold it in for 30 seconds. Use a pin. Once you have reset the router it will default to a generic user name and password. The default user and passords are admin admin or user user
If you still have trouble call support
Telephone (North America) 877-ZHONE20
Posted on Aug 03, 2009
Help log facebookcommyi cant figure out how to change user please help
Log your grandson out by clicking on the log out in the upper right corner. Then go to www.facebook.com and log yourself in with your username and password.
Apr 24, 2014 | Microsoft Computers & Internet
I cant get my emails becouse i cant remember my password or username for sky mail
You will need to go to the log-in page and click on "Forgot Password" and that will help you re-set your password.
Hope this helps! Please rate my answer :) Thanks!
Jun 12, 2011 | Computers & Internet
Sir i have forget my admin password i want to recover it now tell me the procedure
Default admin username: smcadmin Default admin password: smcadmin
This is the default username and password for your SMC 24-Port Ethernet Switch to log into the setup page. Also by default the ipaddress to log into the setup page is http://192.168.2.1
Thanks in Advance!
With Regards,
Prema.
Jan 06, 2011 | SMC (SMC6128L2) 24-Port Ethernet Switch
Need password for log in to SMC Barricade 7004 VWBR Router
The username could be: admin
and the password could be: passoword
the password could be: admin
Jan 01, 2010 | SMC Barricade 7004VWBR Wireless Router
The default password isnt correct, cant log in. I reseted the device many times, and unpluged for hours/days but the default password still doesnt set back...so i cant use the device because with default...
According to SMC the default password which is case sensitive is: smcadmin you enter that into the SMC web interface found by typing 192.168.2.1 into Internet Explorer's address bar.
The full manual is here,a nd their support site is here
If this helped you then please help me and vote, thank you
Oct 12, 2009 | SMC Barricade SMC7004VBR (SMC7004VBR-CA)...
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
Username and password acepted- tries to connect the page
Try rebooting the server. What are you running on the server?
Mar 11, 2009 | F5 Networking Firepass (f5-svc-4007)
Computers & Internet Logo
Top SMC Computers & Internet Experts
Prashant M
Prashant M
efs_perpends
efs_perpends
Resolution IT Dubai
Resolution IT Dubai
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
