Question about Bosch Axxis+ WFR 2460 Front Load Washer
Dyson cr01 fault code f18
My washing machine has this fault code anyone got any suggestions of how to avoid the repair man
Posted by karen taylor on
5 Related Answers
Anonymous
SOURCE: Bosh Washing Machine F18 fault
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
Posted on Oct 11, 2008
Anonymous
SOURCE: Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Posted on Dec 24, 2009
richroth
Richard Roth
  • 9472 Answers
SOURCE: my bosch logixx8 washing machine
Open the service flap, bottom right corner, and clean the pump.
That should do the trick
Posted on Nov 29, 2010
john_cross
  • 6277 Answers
SOURCE: my washing machine keeps stopping mid-cycle &
'F18' for a Bosch is 'pump/drain timeout'
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 14, 2011
Anonymous
  • 59 Answers
SOURCE: Error code F18 for Bosch Maxx 7 Silence washing
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Posted on Jun 04, 2011
Can you please advise me how to turn off the auto rotation on a Dyson CR01, as I am getting the F18 fault,
Wow ,OK check it to out,first of all dyson is built for auto magic rotation when ready to vaccumm.if u disconnect it u stop your roller brush for good.u might as well walk around then to vaccumm with a little hand held.sry.
Jan 05, 2015 | Dyson Washing Machines
Dyson repair manual
Hi there, it's Jack at Dyson.
An F11 fault code means 'no motor action'. Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
If you would like to discuss your concerns further with one of our experts, you can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
Aug 11, 2014 | Dyson Memory CRO1 Front Load Washer
Dyson cr01 not spinning
go to the facebook group DYSON CR01 REPAIR.
READ MORE THAN YOU NEED TO KNOW ABOUT THESE MACHINES.
Apr 26, 2014 | Dyson Memory CRO1 Front Load Washer
Dyson cr01 fault F4
Hi Sue, it's Jack at Dyson.
An F4 fault code means 'inner door opening'. Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
Mar 17, 2014 | Dyson Flowcheck CRO1 Front Load Washer
Dyson cr01 clicking noise
Hi Kenneth, it's Jack at Dyson.
Unfortunately since 31st December 2012, we have been unable to support CR01 and CR02 washing machines with spare parts or servicing. In October 2012 we proactively wrote to all CR01 and CR02 owners that we'd interacted with within the last 3 years to make them aware of this.
Alternatively you may wish to check with local repair services for advice - please note, we cannot recommend or endorse specific repair companies.
Dec 12, 2013 | Dyson Washing Machines
Dyson CR01 - How to clear F8 - Overfilling : Turn Off Water?
Don't panic, simply call our Helpline free on 0800 298 0298. One of our advisors will be able to assist you!
Kind regards
Darran
Dyson Customer Service
Apr 07, 2010 | Dyson Flowcheck CRO1 Front Load Washer
How to repair a F 11 fault on a DYSON CR01 flow check
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Oct 22, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Dyson washing machine fault
Hi its Darran at Dyson. If you paid for a repair then there is a 12 month guarantee on any work that was carried out. To arrange a visit, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Mar 26, 2008 | Dyson Flowcheck CRO1 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
Top Bosch Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
