SOURCE: When the DeWALT DE9118 charger
It sounds like you need a new charger I'm afraid. If you want to double check though, take the housing apart (4x security torx screws in the underside corners) and check the little glass fuse on the pcb. If either main fuse or glass one is blown you have a problem with the board and it's not worth repairing. If both fuses are ok I would suggest you might have a dry solder or broken leg on one of the pcb components. You could possibly resolder it if you can find it and it has enough contact left.
