Hi
Error F2 appears when there is something wrong with the
keypad. Check that the keypad is firmly connected with the control board, then
press Cancel, if error appears then you'll need to check the keypad. To resolve
this issue disconnect the power to stove. Now gain access to the back of the
clock (electronic range control or ERC). Now unplug the touch pad ribbon
connector from the ERC, it would be a flat wire approx. 1 1/2" to 2"
wide. Make sure that the cable is not cut and nothing is shorted on the keypad.
Turn power back on to stove and observe. If the error is still there then you
would need to replace the board. Hope this helps...please post back for further
assistance.
Daniel
