SOURCE: maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
SOURCE: maytag gas dryer wont heat
Since your hot surface ignitor is glowing, that means it is trying to heat, or that all the temp. switches are good and the timer is sending the signal. First check that there is actually gas pressure to the dryer. But the common problem is the coils on the gas valve. There are two, called the booster/holding coil, and the secondary coil. They are purchased as a set (part #279834 / $20.00) if it is the same as my mdg8600aww model. If that doesn't work, then likely the gas valve itself.
Sometimes those coils will open circuit when they warm up, and close when they cool down, giving you an erratic operation symptom.
SOURCE: dryer heats up ,then loses heat after 10 minutes
Based on your description, you may have a Gas Valve Coil failure. Below is a link, courtesy of www.repairclinic.com, showing the part(s) involved. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8c237i3479&PartID=3479
More assistance below: You will need your model number to access the information.
Model Number Locator Tip
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag.
1. Parts Breakdown/Disassembly Procedures: http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
2. Diagnostic tips:
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter
Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
