Question about ASUS SiS Chipset P4S533 (P4S533 PA W/LAN) Motherboard
Ddr ram sdr ram i am same time input that tw0 thats not show two ram capacities just show one ram'' asus p4s533 model please help me
Posted by safran0785 on
Anonymous
    Problem Solver:
  • 14 Answers
Do u mean insert a ddram and a sdram simultanoesly? course it will only show a memory capacity.
Posted on May 14, 2009
  • Anonymous May 14, 2009
    go to www.asus.com website, you need to update your bios.
CANT DETECT THE AUDIO DRIVER ON MY BUILT IN MOTHERBOARD P4S533-MX... PLS HELP ME TO FIX OR WHAT IS THE CORRECT DRIVER FOR IT...
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
May 06, 2011 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Where can i get asus p4 s533mx vga drivers?
on this page:
enter your model number to search (P4S533-MX).
select your operating system and go.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse
Feb 25, 2011 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Which kind of RAM my motherboard is compatible?
It supports maximum of 2 GB of DDR RAM
DDR here means DDR 1 and not DDR2 or DDR3
Rate it, if it helps.
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
chandrashekhar
Vga drivers
you can download all drivers here: http://support.asus.com/download/download.aspx?SLanguage=en-us
you can search for the exact model number (P4S533-MX) on that page, then select your operating system on the next page and choosing the latest version of the VGA-driver on the next page you get.
don't forget to reboot the computer after you've installed the driver.
Jun 22, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Hi safran0785,
The Asus motherboard, P4S533-MX can run two different types of memory.
(Just not at the same time & in different slots).
You can use 2, 184-pin memory, PC2700/PC2100 MHz or PC1600 up to 2GB. (1GB DIMMs) inserted in the two memory slots closest to the CPU.
Or you can run SDR memory, 168-pin PC133 or PC100MHz DIMMs up to 1GB of memory in the last two slots farthest from the CPU.
You can not run both types of memory at the same time.
The 184-pin DDR PC2700MHz memory is much faster then SDR memory.
The maximum amount of system memory supported is 2GB.
Need more information/questions, just post here.
Good luck safran0785!
Mike
Mar 22, 2009 | ASUS P4S533-MX Motherboard
Hi i have a asus P4s533-mx and with a 3GHZ processor and with a geforce6600 (agp) and the games tend to freeze and i have to reboot my system?. any help please
It is the video card. Newer games are so graphic intensive that they freeze up the system if there is not enough video memory. You could try upgrading RAM but I had a problem running newer games until I installed a graphic card that had at least 512 mb video ram onboard. Hope this helps.
Jan 10, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
I need driver asus p4s533mx
Hi there
Get the drivers here
Regards
Dec 24, 2008 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
ASUS SiS Chipset P4S533 (P4S533 PA W/LAN) Motherboard Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
