SOURCE: Replacing old fan with Hunter 20763.
People find all kinds of creative ways to wire things. White wires are always supposed to be neutrals and therefore should always go with other white wires, and colored wires should always be hot and should always go with other colored wires. If you have a voltage tester you could test to see if in fact the blue wire is actually the hot and the white is actually the neutral. (test each wire to a ground). If the previous fan was wired backwards, it would not affect the operation of the fan or lights at all. But you'd probably want to make sure the new fan was wired properly. In that case connect the white from the fan to the neutral and the black and black/white to the hot.
SOURCE: I am trying to install a new wireless hampton bay in a hunter
you need to get the right remote for the right fan....or it will never work correctly.
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
SOURCE: I purchased a display Model
Hello. Here is the owner manual for your fan http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41228.pdf
j.
SOURCE: I have a Hunter 21871
I'm trying to do just that right now...looking fir a little help with wire color identification. I'll advise you if I have luck.
