Question about Magic Chef Microwave Ovens
PAPER DIRECTIONS
MODEL # MCK9990 SERIAL # 20805978AND THE FCC ID # C5F7NF86709000. DATE ON MICRO WAVE AUGUST 2002
Posted by LADONNA SCHUCK on
William Miller
  • Magic Chef Master
  • 9,179 Answers
That FCC number means it was made by Daewoo, but it may have a Magic Chef or other brand name.
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
For Magic Chef in Canada call 866.587.2002
Posted on Jun 10, 2013
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Need to have Panasonic Micro-Wave
An old saying comes to mind: "If it ain't broke, don't fix it!"
But if you have some concern, I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
Anonymous
  • 1124 Answers
SOURCE: I would like to buy
I found JVM1840 next model of yours (JVM1740) if you know the right size may be fit.
You can get that here:
http://cgi.ebay.com/GE-microwave-Charcoal-Filter-WB02X10733-JX81B-6157-4pk_W0QQitemZ360089477635QQcmdZViewItem?hash=item360089477635&_trkparms=72%3A1205%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Posted on Oct 03, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave seems to be working
Chances are you have a shorted high voltage rectifier diode or a bad magnetron, but it may be a bad high voltage transformer.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
If you'd rather have a pro take a look, I would recommend that you contact Whirlpool customer service to find your nearest Whirlpool-authorized service center.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
Posted on Oct 27, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Jenn-Air micro-wave oven serial number #JMV8208AAS
This is the door latch, and replacing it is not a bad job for a do-it-yourselfer, in case you or someone you know may want to do it.
You have to separate the door panels (as shown in the attached photo) and then you'll see how you can replace the broken door latch. (Don't lose the spring!)
Or you can watch a YouTube video (not a video I made) that demonstrates how it's opened.
If you don't want to do it yourself, you can find your nearest Jenn-Air / Maytag-authorized servicer here.
They generally charge about $75 to visit the home, $75-90 to do the repair work, and the part may run about $15 or so. If nothing else, you can save about $75 by taking it to the shop yourself.
I'd suggest a helper for that task, and you can download installation instructions here.
Posted on Nov 08, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 24, 2008
How to remove LG microwave to check fuse? Model LMV1813ST Serial: 102TRXT01402
The service manual for your model is here. That and my video here will give you disassembly info.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave
Jan 28, 2018 | LG Microwave Ovens
My microwave is making strange sounds and is emitting a burning smell. Can I see if it has been recalled? Model MCO160UW
It may be grease or food particles on or behind the waveguide cover / spatter shield that protects the magnetron and waveguide.
If you need a new waveguide cover, it can be ordered here: https://mcappliance.com/wave-guide-cover-3511406200.html
If you have other questions, please contact me directly for full details since FIxYa doesn't always inform us of follow-up questions. Remind me of the full model number and FCC ID number from the tag and your detailed symptoms.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Dec 06, 2017 | Microwave Ovens
I have O'Keefe and Merritt stove with attached microwave labeled Tappan FCC ID ABM964To3. The "start" button on the microwave quit working. Can I get this repaired?
I had very old parts for the tappan units but they have been out of circulation for quite some time. Unless this is a new tappan that I am not familar with, Most of those parts are no longer available. The FCC ID does not help, you need a model number of the unit to try to look up parts. A Microwave puts out radio waves and such has to be regulated by the FCC. Federal Comunications Commission. That number wont help find parts for the unit. Sorry
Oct 03, 2017 | Tappan Microwave Ovens
I need the manual and cookbook for the old Quasar Heat Wave Microwave Convection
Look at the model number tag and find the FCC ID number.
Enter the number (in two parts) as shown on the FCC ID page here:
https://www.fcc.gov/oet/ea/fccid
In the list of exhibits, look for the owner's manual.
If it's not there, you should be able order it via the links on my part ordering page here:
http://www.microwavecontrol.com/parts.htm
[email protected]
May 05, 2017 | Microwave Ovens
I have a nn-sa6615 micro wave showing H98 message when pressing start
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
For free DIY and other help and advice, feel free to contact me via my site.
Always include your FULL model number*, FCC ID number*, and detailed symptom information.
* from the tag in the cooking cavity or elsewhere on the oven (or send a clear photo of tag)
William E. Miller
Jan 22, 2017 | Microwave Ovens
My feigidiare micro wave door won't close tight
I would really need the full model number to help you.
Feel free to contact me via microwavecontrol.com with your full full model number and FCC ID number from the tag or even better, a clear photo of the tag itself.
Sep 30, 2016 | Microwave Ovens
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Microwave
You can download that manual here.
You will need the free DJVU viewer to view or print this manual.
Aug 14, 2008 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
142 people viewed this question
Top Magic Chef Microwave Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
