Help! I have hard disk Seagate U6 Model ST340810A 40GB and some how i was open the cmd window and start scanning for erro on my hard disk using chkdsk /r /v /i /c and it ask me to unmount hard disk and i select "yes" and it scan my hard disk with all those option that i told you (chkdsk /r /v /i /c and after finish scan the hard disk and some how i don't know what happen to my Seagate hard disk I can't open my hard disk and I right click and choose properties to see the hard disk section and some how my Seagate hard disk became RAW (File System: RAW) do you think that i did something wrong with scanning my Seagate hard disk using chkdsk /r /v /i /c unmount selection? My Seagate hard disk plug in using usb adapter (usb to ide cable) How do i fix RAW drive to a normal drive without losing data? so i can open my hard disk again
OK! Have you tried this Seagate external hard disk on other computers? Is it also detected as RAW file system there? Does the PC Windows ask you to format this hard disk before any access there? If so, your external drive may not be seriously damaged or corrupted. Before you really format this drive as you are asked, merely scan this RAW drive with external hard disk RAW file system error recovery software.
Read more detailed data recovery clues here:
http://www.icare-recovery.com/raw-drive.html
Hope these words can help you out.
Your data is already gone. The drive is raw. No partition no format.
here is a link to a free data recovery program, this probably wont work but may be worth a try
http://getdataback-data-recovery-for-ntfs.soft32.com/free-download/?lp=dsa&tg=us&kw=_cat%3Asoft32.com&mt=b&ad=35354358678&pl=&ds=s&gclid=CIa78aSmk74CFc5ffgod9gEAlA
just be sure to opt out of all garbage they want to infest your computer with.
SOURCE: how to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
Let me know if you need further assistance.
Thanks for using FixYa.
SOURCE: how to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Do a google on "seagate LBA 0" there are some diy options.
If it's just a case of bad sectors these guys can help you do remote data recovery over the net. http://FreeDataRecovery.us
