Crosley CW6000 Front Load Washer Logo
Anonymous Posted on Jun 05, 2013
Water in tub after cycle has finished
Switched water pumps, no kinks, no debris in lines. Door switch turns off, but some more water still comes into the tub, door switch should not let me open door if not finished.
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 40 Answers
  • Posted on Jun 05, 2013
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
40
Questions
Helped
6966
Points
145
On our Kenmore front loader the guy came out and pulled the front lower cover off and opened the large round plug cap and there was the kids paint ball ammo stuck in the pre-pump end. Then he re-set the computer board with his tester. When this happened the second time, I repeated what he did, except I unplugged the unit. It cleared the memory and works fine...
1 Related Answer
Anonymous
  • 1294 Answers
  • Posted on Apr 30, 2007
SOURCE: The tub never starts to spin when it hits spin cycle.
If your washer functions when the door is shut it cannot be a door problem. The likely thing here is you may have a drain problem....your drain oulet filter (or out pump) could be blocked. This requires cleaning; when the washer goes thru all the functions except spin it is most likely your drain is clogged. Aft u have cleaned the filter & pump check by a small spin. Before you attempt, wall socket off & keep bucket handy to collect water.
Kenmore elite 100 series.. fills with water for wash but drains immediately
If your Kenmore Elite 100 series washing machine is filling with water for the wash cycle but immediately draining without actually washing the clothes, there could be a few potential causes:
1. Faulty or clogged water level pressure switch: The water level pressure switch is responsible for sensing the water level in the tub and signaling the washer to stop filling once the appropriate level is reached. If this switch is faulty or clogged, it may be signaling the washer to drain the water immediately. You may need to replace the pressure switch or clean the hose that connects it to the tub.
2. Clogged drain hose or pump filter: A clogged drain hose or pump filter can prevent the washer from properly draining the water, causing it to immediately drain as soon as it fills. Check for any clogs or blockages in the drain hose or pump filter and clear them if necessary.
3. Broken or faulty drain pump: If the drain pump is broken or not functioning properly, it may not be able to properly drain the water from the washer, causing it to immediately drain. You may need to replace the drain pump if it is broken.
4. Malfunctioning control board: In rare cases, a malfunctioning control board may be causing the washer to immediately drain after filling. If none of the above solutions work, it may be worth having a professional technician inspect and potentially replace the control board.
Dishwasher stops working a few minutes after being started
Make sure the water is turned on to the unit first--next, is there water entering the tub? Check the float switch--the round, plastic, "flying saucer" shaped object at the bottom of the tub. Gently lift up on it and carefully listen for a very soft "click" sound. That is the tiny switch underneath working. If something gets trapped under the float switch, the washer won't fill with water. Next, if water is indeed in the tub, did you hear the motor pump running? If it runs and then stops, there might be a problem with the control board--check to see if the drain pump works properly--cancel the cycle and listen for the drain pump turning on and draining out all the water. On almost all dishwashers, at the start of a cycle, the drain pump will turn on briefly to pump out any standing water left in the motor base(you can't see the water but it's there) so it doesn't get sprayed onto your dishes. Then, fresh, hot water enters the tub, when the water level reaches the proper level, the float switch rises, tells the computer enough water is present, then starts the main pump. If the water is not being drained out, try to listen for the drain motor humming. If it is running but not draining, it is probably jammed with food or other debris and must be cleared. If the water is turned on but no water is entering the tub, check the inlet water valve underneath the washer--the water line is connected directly to it. It is electrical and operates on 120v. You will need to carefully disconnect the connector from the valve, activate a cycle, and using a voltage meter, check to see if 120 volts is present. If it is there and no water is entering, most likely the valve is bad. If there is no voltage at the valve, either a wire is broken or the main board is defective.
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Water will not drain. sewer line is not pluged. Customer service says I could have a plugged filter at the pump ( we have dogs). How do I get to the pump to unclog it. Model EIFLS55IIW woody
Hi agnes! Washing machines, including those built by Frigidaire, have internal pumps. These pumps help drain out the water from the washer tub between the wash, rinse, and spin cycles. If the pump is damaged or the pump pulley system is frozen/stiff, the water can become trapped in the washer tub. In both cases, the pump assembly needs to be replaced. You can check by looking for a few signs that a pump is dying or already dead.
1 Start the washer and wait for the washer tub to fill with water. If you do not hear water or hear a motor whirring, the washer motor may be dead.
2 Open the washer lid in mid-cycle. Note whether or not the inner tub is still spinning around. The inner tub is the inside surface of the washing compartment with many holes for water draining. If the tub is not spinning but the motor is running, it is possible the pump is dead. Check the pump pulley by removing the pump from the washer and trying to rotate it by hand. If the pulley doesn't turn freely and is frozen or stiff, replace it. Also, if the agitator is moving but the tub isn't, this is a sign the pump is dying. For front-loading washers, do not attempt to open the door mid-cycle. Look through the glass door. If there is enough water to come up against the door, the pump is malfunctioning.
3 Wait for the washer to finish its cycle. Open the unit. If water is still in the tub, the pump is likely dying or dead.
My washer is not draining. I used to be able to reset it and it would work but now it wont start on any setting and is full of water. Is there anything i can try.
If your Maytag washer is not draining, follow these procedures to find out what is the problem.Set the timer in the spin cycle and pull the knob to turn the washer on. If the washer motor doesn't run, check the following parts.
The wall outlet: Make sure that there are about 120 volts present at the wall outlet. Connect a good working hair dryer to see if it works.If the hair dryer works ok, then the problem has to be in the washer. If the hair dryer doesn't work, then look for a blown fuse or tripped circuit breaker.
The lid or door switch : The lid switch is a safety device use to stop the motor from running if the washer door is opened during the agitation or spin cycles. A bad lid switch could be the reason for your washer not draining.
The pump : Check for obstructions inside of the pump and inside of the tub.
Check the pump impeller, the pump belt, check the drain hose for any kinks. Any problems in these parts could be the cause for the Maytag washer not draining.
Lower the drain hose to a bucket to see if the water drains out. If the water won’t drain or just trickles out, most likely there is an obstruction on the pump or inside of the tub and that could cause the washer not draining.
To check the pump, remove the front panel, lean the washer against the wall and bail the water out with a plastic container.
To check the pump, remove the pump belt and turn the pump pulley to make sure that the pulley is turning freely.
Put a couple towels near the pump to catch any water from the pump. Remove the tub to pump hose at and check inside of the pump for any obstruction. If you find an obstruction remove it.
If you don’t find anything, reinstall the hose and remove the hose at the tub, and check for obstructions.
A Maytag washer not draining could be cause simply by a kink drain hose.
You need to make sure that when you replace the pump, you adjust the belts properly.
Washer over fills and water comes out the door. Water continues to run even durring the pump out cycle just before the spin cycle
  1. Water inlet valve. It may not be able to shut completely when the electricity to it has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow. Remove the washer's cabinet to access it.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
  3. Air-hose. It is connected to the water level switch through a tube. If the tube or hose is cracked or broken, no enough pressure builds up to trigger the switch and shut the water supply off. Check it for any obvious damage.
Stops during rinse cycle and water will not empty out of tub. ? switch to pump??? Now I have a tub full of dirty water that won't drain
Model may vary, but this could be helpful for sure.
1. Unplug machine. Drain out maximum water by lowering the drain pipe into bucket or lower drain.
2. Remove the lower kick plate under the door. There will be a screws in the bottom corners of the panel holding it on.
3. Find the drain pump. It will be on the right-hand side and is
usually white in color. The drain hose from the bottom of the tub
will be connected to it.
4. Remove drain hose from standpipe and connect a wet/dry shop vac (if you have one) to the end of it.
5. Turn vacuum on and watch the drain hoses from the tub and from the pump. If the hoses collapse, you have a clog somewhere.
6. Remove the drain hose leading to the pump. Check the impeller area of the pump for debris. This is usually where coins, clothing labels and other items get caught.
7. Clean out the pump and drain hoses. Located in the hose coming down from the tub is the filter, check this out for cleaning.
8. When finished, reconnect any drain hoses that you previously removed making sure you get a good seal with the hose clamp BEFORE you fill the machine. If you notice a leak during fill, hit the "cancel" button to stop. Make sure you place the drain hose back in the standpipe too.
F H error
no water error code. first check the the water is on and the hose screen is clean.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
1helpful
2answers
Tub won't fill
hi there,
F/H No water detected entering machine or Pressure switch trip not detected.
Or
Verify CCU operation.
best of luck....
F-H code and water won't stop
Or
Potential Causes
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Verify CCU operation
Top Crosley Washing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
