Question about Maax Crescendo - 100085-000 Bathtub
Heater bought maax crescendo from 3rd party and was told it had a heater which it doesnt. can water heater be put on ?
Posted by julie gubler on
Gene Haynes
  • Maax Master
  • 5,391 Answers
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 05, 2013
What is a requarement for motor, do we need it to be bonding ?
Motor must be grounded with ground wire.
Some local codes require outdoor motor shell to be bonded, with a ground rod driven into ground and ground wire attached... in addition to ground wire back to panel.
Never hurts to bond outdoor electrical devices.
May 20, 2014 | Maax Water Heaters
Can't locate the year of manufacture of my Rheem Fury Model 29-40S-2
Generally the year of manufacture for Rheem is 3rd and 4th digit of serial number. 06 is 2006, 92 is 1992 etc.
Older gas water heaters are better than new ones, and easier to keep repaired and maintained.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Regardless of age, the key factor is whether tank is rusted, or rusting.
Open drain valve and check if water is rusted.
http://waterheatertimer.org/Replace-anode-rod.html
Aug 18, 2012 | Rheem Fury 40 Gallon Natural Gas Water...
I have a reliance model 501 electric water heater thats 8 yrs old who's responsible if it blows out the thermostat and floods the bldg I'am on the third floor codo
The person who owns the water heater is usually the responsible party. If it is in warranty, I have heard lately that serveral of the insurance companies have sued the manufacter and won but this is rare at this time. If unit is working I would put some type of preventive measure to stop if from drowning the people below and ruing your condo too.
Water Cop'
Brust Buster
Watts water stop
this is just to name a few to protect yourself and other under you.
Oct 04, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a jet that is tipped way down and not good pressure. Can I just manually adjust the direction? How do I adjust the pressure? I am worried as this is the first jetted tub we have owned and I don't...
Yes you should be able to adjust the eyeball. Simply grab it with your fingers and move it where you want it to be. Some jet trim are adjustable from the outside face of the jet. take a hold of the outside of the trim and turn it both directions until you feel more water pressure come out. this means the jet is open.
May 25, 2010 | Maax Crescendo - 100085-000 Bathtub
Infiniti hot tub reads HL
the pump just pumps, do you have a heater it would be about 2inch in diameter adn in line with a cord comming off of it that plugs in seperate from the pump that is the heater,
May 24, 2009 | Maax Infiniti - 100055
Maax Crescendo - 100085-000 Bathtub Logo
111 people viewed this question
Top Maax Water Heaters Experts
Paul Carew
Marvin
Marvin
Are you a Maax Water Heater Expert? Answer questions, earn points and help others
