Moen & Replacement Cartridge  Logo
Alan Welsh Posted on Jun 05, 2013
Removing Moen Cartridge with BROKEN shaft
The brass shaft actually BROKE OFF the other day when using it normally!! I not only have to replace it, but I also have to figure out how to get it out WITHOUT ANY shaft to pull on. So any advice would be very helpful. I'm planning to do a lot of drilling to get the old one out, and may leave the water on to see if before I drill deep, pressure would force it out. [ When drilling, I won't hit the sides of the valve body itself. I've replaced two other "normal 1222's" before, so I know to burnish and clean the body before inserting the new one. ] AFTER I drill and get the inner parts out, I'm sure that I'll be left with the plastic shell. HOW do I get that out without destroying the sides of the brass body? Right now, I'm thinking "acetone" or even methyl alcohol. Any ideas out there??
  • Alan Welsh Jun 06, 2013
    OK --- Got it. I also doubt leaving the water on would blow it out if drilled, But I might first see if I can turn it a bit with pliers with 50 LBS pushing. If it blows, I'll be happy. What about the solvent idea?. I think I probably have an old valve to test the solvent method on. since it's a shower, I won't worry about contamination. Do you see any value (or danger in the 1/2 tap solution floating around? One online plumber smugly said that the tap idea wouldn't work, he knew how to easily do it, but other plumbers were too dumb to understand his explanation, so I should just hire a plumber. ... Hmmm, I probably would if I have a "regular plumber" that I used all the time in the past. I'm planning on drilling first, and I will be careful not to nick the body. Thanks again.
  • Alan Welsh Sep 17, 2013
    I finally replaced it in about 4 hours. First, the water pressure idea was crazy. I doubt SCUBA tank pressure would have worked at 3000Lbs. I did tap out the center brass control shaft with my drill, and used the "screw against wrenches / sockets" method. Unfortunately, my screw hole was a bit too big, so it didn't hold completely before bursting at the sides of the screw. But, it did work well enough to pull the thick 5/8" ? metal shaft out, destroying the front plastic piece. (Yes, it took THAT much force). Once I had that big shaft out, I could see inside, and there was a nice channel (between the valve body and the plastic cylinder) on both sides of the plastic that extended back to the inlets. Without scoring the valve body sides, I was able to use a common screwdriver and pound into the plastic cylinder, by pounding towards the inside center from the outside edge. That broke off a fair sized chunk and then I could use some strong needle nose pliers to finish breaking out the cylinder. I polished it up some, and replaced the cartridge--job done. NEXT TIME..... I recommend: I would of course buy a proper MOEN puller, since this would have worked in a normal situation. They appear strong enough to do most jobs and are only about $15 or so. However, if that didn't work, I'd repeat much of what I just did: Remove the large metal shaft, and break up the front plastic any way you can. Once you do that, keep an eye on your new cartridge so you know which areas that you can't score without tearing the wall out and replacing the whole valve body. Now you can just destroy that plastic cylinder fairly easily. Once one side is broken out, it comes out easily. I'd still like to see someone try the acetone or other solvent method of just dissolving the plastic parts. (Is someone that has an old cartridge body and some acetone willing to try it and report??) Even if it does work... think about it... if you have PVC pipes..... no, don't even think about it !!
Will Cordelo
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jun 06, 2013
Will Cordelo
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
6420
Points
5
Alan, I'm a certified plumber for over 30 years specializing in service. I hate telling you this but what you have is a Moen posi-temp and there is no tricks or easy way to remove it other than a cartridge puller which won't help in your case since it's already broken. Just break out your drill and carefully have at it, BUT don't leave the water on it won't help and may be dangerous and/or ruin your drill. For some reason on all Moens cartridges the rubber grommet tend to adhere themselves to the brass valve body's. Sorry, wish I had better news...
3 Related Answers
kapishtech
raj somaiya
  • 2272 Answers
  • Posted on Jun 07, 2010
SOURCE: how remove the broken bathtub cartridge(Moen 1222)
The exact procedure to remove the old cartridge is with a plastic removal tool.With replacement cartridge you have to buy this plastic removal tool.Also there is same metal removal tool available.With the help of this tool you can easily remove the old cartridge.
Moen Cartridge Replacement Instructions
Moen shower faucet cartridge replacement is a project that will take some time to get done right. When is it time to replace a Moen cartridge? If you are like most people, you won't want to replace your old Moen cartridge until your old cartridge is starting to show its age.
Replacement is necessary, usually, once the old faucet starts to drip. Thankfully Moen faucet cartridge replacement is not difficult. However, if you are uncomfortable with doing the repair yourself, do not hesitate to call a professional plumber to do the job for you. This will guarantee that the job is done right.
If you follow these Moen faucet cartridge replacement instructions you will be able to replace your old cartridge by yourself. First of all, as with any plumbing repair, make sure that the water supply is turned off. Open the faucet to remove water pressure from the lines and let the remaining water drain from the pipes. You will then need to remove the faucet's handle by removing the decorative cover and removing the retaining screw. This will allow you to remove the handle.
Once the handle has been removed, work on releasing the splash plate from the wall. Generally there will be one or two screws to remove and the plate should release from the wall easily. From here the process begins to get a little trickier. Insert a shower stem socket onto the faucet valve's retaining nut and release the nut. Your Moen cartridge removal will be complete once you grab the cartridge with a pair of pliers and pull straight out to remove the old cartridge.
Clean any surfaces that you have access to and replace with the new cartridge. Follow all of the previous instructions in reverse order to re-assemble your shower faucet. Check to make sure that all the connections are tight before turning the water back on and testing the system out.
Now in your case the broken/cracked while removing the old cartridge so try this procedure carefully to get the stuck -up old cartridge out.
TAPPING the Threads into the Cartridge:
Carefully  hold one tab on the cartridge tight against the brass lip on the faucet body with needle nose and try  to drive the 1/2" tap into the smaller bore of the cartridge. It will take  about 15 minutes to slowly work the tap in all the way (maybe 3 turns?). Then  back out the tap... remove needle nose. [remember to turn the tap 1/4 turn back, for each 1/2 turn forward ... this clears the metal particles from the tap and makes the next 1/2 turn forward go smoother].
Next, assemble a 1/2" x 4" threaded rod, so it had threads all the way to the two jam nuts on one end)... If you use a bolt, get one with threads all the way up to the head. you may find it hard to find - so try a carriage bolt and spin a nut all the way up to the head .... continue:
next on the bolt goes a 1/2 nut (this is the "jacking nut") and a flat washer so the jacking nut can spin easily against the next piece, a 1/2 drive socket (7/8" ) with the square hole toward the washer and jam nuts ( bolt head ).
The open end of the socket faces the brass body of faucet and rests on the round brass lip... having the same inside diameter. This allows a space for the cartridge to be pulled into ( a cavity). Thread the bolt into the tapped cartridge and snug it up so the 7/8" socket is aligned with and resting against the brass body. If the cartridge spins smooth, the threaded rod is GREAT. You can just work with the 1/2" rod and use needle nose (or similar) to stop the  cartridge from spinning, to get the rod threaded into the tapped threads in the cartridge... then, slip on the socket, washer and nuts.
Now snug it up tighter. Check socket alignment. Then begin turning the jacking nut ( the "extra" nut) until it contacts the flat washer and 7/8" socket. Now, as you continue to tighten the jacking nut, it will pull the 1/2 bolt (threaded rod) away from the faucet... and the cartridge will come along too. [You have to prevent the 1/2 rod from spinning while tightening the jacking nut. put a wrench on the bolt head.]
This procedure is bit lengthy and requires some appropriate tools,but this will release the stuck cartridge out.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Anonymous
  • 68 Answers
  • Posted on Dec 29, 2008
SOURCE: After consulting with Moen re:
If the water is off but still coming through, open a tap or two on one of the lower levels.
Basically the old stem does come out thru the top of the valve. Hopefully Moen sent you the tool to do this job. The tool is a 3/4"diameter about 4 inches long. Even on one end and two little tabs on the other.
Take the handle off stem. Remove the upper retaining nut, usually chrome. Pull out the two plastic upper stem pieces. Insert the 2 tabbed end into the stem area. You will feel the tab drop into the retainer ring. Slowly rotate the retainer ring out Counterclockwise. After the retainer ring is out then put the long screw in the stem and pull it out. Sometimes a little leverage helps here.
You will have TWO retainer nuts. The first one is easy just under the handle, the second will require the special insert tool.
Please rate this response and good luck, Phil
DAVID CAYCEDO
  • 94 Answers
  • Posted on Apr 24, 2010
SOURCE: New MOEN 1222 cartridge leaks
remove it and carefully inspect it, you might have scuff'd up the rubber's on the cartridge when you inserted new one.clean out,look in hous'ing for any foriegn mat.etc .you may need another new cart.
Moen cartridge retainer broke tabs Stuck in valve how to remove
No, replace the whole thing. That is bad design and inferior parts. Ask Moen to replace it under warranty. They might say No, but then again, they might know of a fix or if they had a bad batch of plastic parts.
Moen 87786 Kitchen Faucet, seized and now Broken cartridge retainer ring/nut removal?
get in a plumber to remove the unit and have anew unit installed
Moen ca87553
You need a #1225 replacement cartridge. Pop the cap off of the handle. Use phillips screwdriver to remove the handle screw. Pull the handle off. Next, unscrew the two screws holding the cover plate on. After removing plate, there should be two integral stops, one on each side of the valve. Close the valves using a straight slot screwdriver. Pull on the brass cartridge spindle to ensure that the water is off. Remove the stop tube, which is a chrome cylinder at the center of the valve body. Look for a brass retainer clip at the top of the cylindrical portion of the valve body where the handle connects. It has a small hole and after you pull it out, you will see that it horse shoe shaped. Use your pliers or an awl stuck through the hole to pull the clip out. Note the position of your cartridge. There is a notch on the end of one side of the brass spindle at the center of the cartridge. Make note of its position. If you install it and get hot and cold reversed, just take the handle back off, and spin the brass spindle 180 degrees. The replacement cartridge comes with a white plastic tool designed to make removal easier. Use it. After loosening with the plastic tool, take your pliers and grab the brass stem. Pull as straight as you can. If cartridge will not budge, you might need a Moen cartridge removal tool. Do not spray with WD-40 or Liquid Wrench unless you like that taste in your water. If your clip won't go back on, it's because you didn't align the two ears on the cartridge. The ears should be at three o'clock and six o'clock. The cartridge must also be pushed in all the way. Good luck!
I replaced a 1248B Cartridge on my Roman tub because of constant water dripping. I installed the new cartridge and this one is also allowing water droplets. What should I do to stop this?
I would try and find a cartridge that is made of all brass, as Moen do make them. I have about 14 of them still in there packages. They are much better then the one shown in the photo above. This is all that it could be. Take it back, get your $$$ back, and buy the brass one.
Shastalaker7
2helpful
Just purchased the home and the handle on the moen 4551 cp is loose. The handle actually falls off the fixture. There is a plastic grommet or washer that is broken. How do I replace this plastic grommet...
You can find the parts diagram here: http://www.moen.com/monticello/chrome-two-handle-low-arc-bathroom-faucet/_/R-CONSUMER%3A4551 . The washer kit is part number 97274. The lever and the hub and elbow that the handle connects to depend on the finish and whether you need the hot or cold side replaced. Levers: 97557 Chrome 97558 Pol. Brass, hub and elbow: Cold 100552 Chrome, 100552P Pol. Brass; Hot 100553 Chrome, 100553P Pol. Brass.
You may be able to find the washer at a local hardware store (like Ace or Tru-Value). Alternatively, call Moen or visit the Moen site. 1-800-BUY-MOEN or http://www.moen.com/replacement-parts/product?product=IMGLIB:CA84437BN to order replacement parts.
You'll have to pay for the washer kit. However, if the hub and elbow or the lever are damaged, call Moen and see if they will replace it under warranty.
I hope this helps.
2helpful
We have a 20 year old tub shower single valve. We replaced the brass cartridge with a plastic cartridge and water is leaking out of the front when the water is on. Do we need to replace it with a brass...
I'm not now nor have I ever been a fan of the plastic moen replacement cartrideges. I don't know if they still do but probably about twenty five years ago I tried using a few of the plastic replacements,mostly due to high cost of the brass moen factory ones I think every one leaked. Then I actually read on the instructions that it was not unusual for them to leak some. My suggestion is to get a good brass moen magnum cartridge and be done with it for another twenty years. Hope this helps you. Thanks.
3helpful
2answers
How remove the broken bathtub cartridge(Moen 1222)
7helpful
2answers
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
1helpful
I have a Moen shower knob that broke...
You are not the first. Usually you must break the plastic handle to remove it and then you can access the screw and have leverage to hold the brass stem with pliers while you try removing the screw. Caution, do not try to bend the handle to break it off or you will break the brass facet stem. Also, there are two styles of handles: one has a short innercone,the other has a longer inner cone. You need to know this before you purchase a replacement. Goodluck< Macgivor
3helpful
2answers
Moen positemp cartridge won't come out of brass body housing
If the clip has been removed it will come out. these things get incredibly tough to remove. Moen does sell a little puller just for these. I have used a socket with the screw in the stem to act as a puller.
If you have the water off AND your sure your have the correct new cartridge you can give the valve a little heat to help soften things up a touch. Use a heat gun with caution
Top Moen Home Experts
john h
Gene Lawson
deton8 von Splosion
Are you a Moen Home Expert? Answer questions, earn points and help others
