Question about Emerson Refrigerators
Need user manual for Emerson Wine Cooler FR23RD
Looking for a user manual for Emerson
Wine Cooler FR23RD. Any help most appreciated.
Posted by barbleh on
Michael Masters
  • 6,784 Answers
HI. i couldn't find the FR23RD but, i have been told that this manual covers your model. It basically covers FR24SL threw FR24RD. Your model is also covered in this edition. Click to review your manual.
Please rate and god bless.
Posted on Mar 22, 2009
Need Haier thermal electric wine cooler manual:Model #HVTS18DBVS serial #o90800187 Would appreciate info.
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 13, 2011 | Haier BC112G Wine Cooler
I have not been able to find any solutions online and apparently neither has anyone else. Clearly the Emerson FR48 wine cooler is a piece of $#!%. It appears the power supply on these is flaky. I can hear...
check the fam to make sure it spins freely ,, a little wd-40 could help, If the power supply is straining to make the fan move, you will hear that whining sound as its over loading
May 29, 2011 | Emerson (025806803716) Wine Cooler
I need to know where the board RF-5210-56 is located on the wine cooler model hvts18DABB
Number 19 in this photo is the control boards location=> HVTS18DABB Parts Breakdown
and if you need the user manual click here=> HVTS18DABB User Manual Please rate this if helpful and should you have more questions please ask, Thanks Sea Breeze
May 09, 2011 | Haier HVF042 Wine Cooler
What is the lowest temp that the cooler has.
If you got this new, You should have a manual with the hi-est and lowest temp setting in it...If you do not have the manual than you can Google the same question on google search and get a manual,or a forum where they talk about this model.
Mar 07, 2011 | Emerson (025806803716) Wine Cooler
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
My Emerson Model FR23RD is not working due to a power outage and I do not remember the cost of it a year ago, can anyone help?
I have seen this unit on sale for 79.99 @ Target many times over the last year or so.
In fact, it's that price there now and also at Amazon.com.
The highest price that I recall seeing was probably 99.99
Jan 05, 2009 | Emerson (025806803716) Wine Cooler
Emerson FR24RD Wine Cooler
If you are handy with small electrics, or know someone who is...
I had a similar problem and just solved it.
My cooler was leaking and had trouble keeping the proper temperature.
It was also making a buzzing sound which is what lead me to my solution.
BTW - The liquid that was leaking was condensation, probably because the unit was not holding a constant temperature.
Unplug the unit first - no need to get electrocuted.
These units use peltier cooling- essentially a large heat sink with three fans attached.
Click here for more info regarding peltier cooling.
The peltier unit is not repairable, but the fans are; which was what my problem was.
There are three fans on this unit, one on the inside and two on the outside.
Follow these steps to remove them.
  1. Remove the rear cover. It is held on with ten screws. This exposes the two exterior fans and the peltier heat sink
  2. The heat sink is held on with four screws - remove them and pull the heat sink out. The third fan is on a short wire lead, so be careful when removing the heat sink from the body of the cooler.
  3. The two exterior fans are connected to a control panel, the electrical connection is easy to disconnect.
  4. Once all of the wires have been disconnected, you can remove the fans from the heat sink.
  5. The fans are screwed to a mounting plate, which is screwed to the heat sink
  6. You must remove the mounting plate first to expose the screws that hold the fan to the mounting plate. The fans are typical computer case cooling fans
  7. I only needed one fan, but replaced all three because I didn't want to do this job again.
  8. I purchased my fans from Newark.com the prices were better than what I found at the computer websites. Also, these fans are much better than the original and will hopefully last much longer than the three I got from the old ones.
  9. You need one of these and two of these. The total with shipping was around $30
  10. You will need to splice the old electrical connection sockets onto the new fans using wire crimpers or solder them on.
  11. Attach the components in reverse order and power on the unit.
  12. These fnas may move more air than the originals, because the unit seemed to cool much quicker than I remember.
  13. Total time for repair is about 45 minutes
Hope this helps and Good Luck
Nov 26, 2008 | Emerson (025806803716) Wine Cooler
Refrigerators Logo
1,378 people viewed this question
Top Emerson Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Johnny 1000
Are you an Emerson Refrigerator Expert? Answer questions, earn points and help others
