SOURCE: Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
SOURCE: Nintendo Wii only shows picture in black and
HI ,if you checked all your connections and follow the instruction from user manual you need to open up your unit and replace wi-fi module or bluetooth module Regards
We have the same problem. The Wii worked fine until we tried to connect an digital converter box. Then the screen was white/bright with only green visible. TV adjustments didn't make a difference. Prior to this we had an anolog connector. Now the screen is faded with or without any converter.
