Question about Dell XPS M1530 Notebook
Xps shut down
When i want to put my computer on sleep, it takes about a minute or two to actually go to sleep. this started occurring after i gave my computer a full reboot. it never happened prior to it.
Posted by tina24 on
C. Christensen
    Novelist:
  • 177 Answers
Follow This!!!
>Start Menu
>control panel
>power options
>Change plan settings (currently selected Plan)
>Change advanced power settings
NOW, Scroll Through this LONG list of options until you see "Sleep" .
Select/Expand The Sleep item.
Expand "Allow hybrid sleep".
Set Both "On battery" and "Plugged in" to "Off".
Now Your computer will sleep as normal...
See this link to clarify if my walkthrough doesn't wor for you:
http://www.howtogeek.com/howto/windows-vista/disable-hybrid-sleep-mode/
Posted on Mar 22, 2009
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
I have winows vista and it takes a few minutes for my pc to shut down and startup how can i get it to shut down and start up faster
Forget it, it takes what it takes. There is an idea of an external drive, that can be rigged that helps, but It is a waste of resoruces.
Consider using sleep mode, for faster cycling and only shutdown when you actually need to. If this is a laptop, consider hibernate. Both sleep and hibernate focus on faster start ups, but on laptop, if you use sleep and run out of battery, you can loose data that you were working on. ALWAY save and backup.
Oct 15, 2010 | Computers & Internet
I have a HP Media Center PC m1264n desktop.I can turn it on and 1 minute or maybe 5 to 10 minutes into it,it will just shut down,but the power led light on the front of the PC stays on.I reboot it and it...
Is it going to sleep or is it actually shutting down? Do you have to push the power button to turn it back on? Just a thought - if you have Windows 7, go to Start, Control Panel, then System and Security. Now check 'Change when the computer sleeps' under Power Options. Under Edit Plan Settings, what do you have for 'Put the computer to sleep'. Does '20 minutes' show up in the box? Open it and change it to 'Never' and then Save changes. If this didn't help you,maybe someone else can.
Sep 04, 2010 | HP Media Center m1264n - 3.0Ghz 1024MB...
Sleep vs Shut down
It depends on how long computer is being used in a day.
for general use
you can shutdown your computer once in 2 days but i highly recommend not to put in sleep mode and betting putting in hibernate mode instead of sleep mode.
note: most of simple issues are resolved by restarting PC so you can guess now how important is to shut down computer.
Good luck,
Mar 25, 2009 | Apple 24" iMac Desktop
My XPS 1530 will not shutdown, it only restarts
Try running chkdsk /r and then restart the computer. to do that, click on START, RUN, in the open field, type 'cmd' and press <enter>. A dos window will open. At the blinking cursor, type 'chkdsk /r' and press <enter>. You will get a message that the drive can't be locked and do you want to run it the next time Windows starts. Type 'y' and press <enter>. Now shutdown the computerand restart it. Chkdsk will run and it may take some time. Depending on your installation, you will see a blue screen that will show the progress. Sometimes the screen will stay black and the hard drive light will flash. That's ok. Let it run until Windows loads. Wait until it is completely loaded and then try shutting it down normally.
Good luck and let me know how it works out.
Feb 07, 2009 | Dell XPS M1530 laptop. TUXEDO BLACK. 15.4"...
Dell XPS M1530 trouble shutting down
Try this, just to see if the shutdown actually works.
Open a command prompt and enter the following:
shutdown -s -t 05
-s is to shutdown, -t 05 is a 5 second countdown.  Let me know if it actually shuts down.
Feb 02, 2009 | Dell XPS M1530 Notebook
Dell XPS M1530 Notebook Logo
168 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
