Question about Fahrenheat Electric Hydronic Baseboard Heater, 240 Volt
Hello, Buddy of mine ran 10/3 Wire for 2-240V baseboard heaters & Has a 120/240V 2-Pole 20AMP Breaker. Question for you ? He shouldn't of used 10/3 Wire for this 240V equip. The Red wire is not going to be used, correct ? As far as the 2-Pole Breaker, I will be attaching the white wire in the 2nd slot on the 2-pole breaker ? Do you have a Wiring Diagram ?
You get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Posted on Mar 22, 2009
Jun 21, 2011 | Heating & Cooling
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
Jan 24, 2011 | Siemens 20 Amp Single Pole Breaker 120/240...
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
Aug 10, 2010 | Marley Electric Hydronic Baseboard Heater,...
Oct 17, 2009 | Heating & Cooling
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Sep 12, 2008 | Fahrenheat Electric Convector Baseboard...
Oct 28, 2015 | Fahrenheat Electric Hydronic Baseboard...
What about at the breaker, tie red & black into 2-Pole Breaker, Attach Ground. What about Neutral ?
Thanks, You have been a great help.
