Toshiba Gigabeat MEG-F20S MP3 Player Logo
Posted on Mar 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I don´t have the cd of my gigabeat f20, so I can´t transfer music
I can´t transfer music to it. I need the driver o software
wykidtech
Level 2:
  • Expert 99 Answers
  • Posted on Mar 22, 2009
wykidtech
Expert
Level 2:
Answers
99
Questions
0
Helped
27578
Points
208
HERE is a link to the software you need. Like anything you download from the net, scan it with your antivirus program before using.
How do i upload music from my pc to gigabeat 40gb i pod
To transfer music files to your gigabeat, simply connect it to the PC via USB cable. A gigabeat window will pop up on your screen and will direct you to WMP 11 (make sure to click the "Complete" button, or it will not take you to WMP 11). Once you're in WMP 11, assemble the list of music you wish to transfer and press "Sync". The program will automatically begin transferring data to your gigabeat.
Installation failed: Loadlibrary error for Gigabeat f20
Hello
Welcome to Fixya's Community.
In Order to solve your Problem you need to repair the Firmware of your Device, to perform that you shoud Upgrade/Repair the firmware.
Please Download and Install the Firmware Updater and follow the instructions.
Downloads
Firmware Updater for Toshiba Gigabeat MEG-F20.
Additional Help:
Toshiba Gigabeat MEG-F20.Mnual Guide.
Thank You for Using Fixya.
Please let me know if you need any Further Info.
Good Luck.
Gigabeat Toshiba stalls
You r hardrive maybe faulty.
So you'll need to format it. and reload the software.
Otherwise you need to replace the hardrive.
Software here.
http://www.megaupload.com/?d=GTC188NU
2helpful
Gigabeat MEGF-20
Your battery has a low voltage.
You need to rejuvenate it.
I need help
the OS as been delete from hdd , most of the time 'cause formatting hdd with windows
must have other Gigabeat same model fonctional , or call Toshiba and ask for repair center near you they can copy O.S. back in your Blank hdd .
Hope that help a bit
Regard
262422660
Gigabeat F20 and Windows Vista
hi i had the same problem and updated gigabeat room to version 3 , not the actual gigabeat just its pc software , and it seems to work ok most of the time but only if i load gigabeat watcher after plugging in my player . hope this helps ,i emailed toshiba uk but they told me that they have no intention of updating the players firmware ,
29helpful
10answers
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
