Question about Pride Mobility Products Health & Beauty
Transaxle repair does anybody repair them? - Pride Mobility Products Health & Beauty
Posted by Richard Carr on
gladstone sherratt
    New Friend:
    Problem Solver:
  • 7 Answers
You can buy them off ebay for about 99.00 pounds
this may be cheaper then a repair to yours.
Posted on Jun 06, 2013
LEAKING OIL right transaxle
Johnny, Transaxle needs a new seal. you can get or order your seal from any local small engine repair shop. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TORO Wheel Horse Hub Removal and Transaxle Seal Replacement
Replacing oil seal on rear axle of Lawn Tractor 917 288250 ShopYourWay
2007 Craftsman 917 287210 Lawn Tractor with leaking Transaxle
Rebuilding lawn tractor transaxle Part 1 of 2
lawntractor transaxle seal Google Search Ord
Aug 25, 2016 | Garden
Can a vss for a 4t60e transaxle be used in a 4t80e transaxle and visa versa ?
Go to ATRA Seminar manual.PDF Transmission repair at oskin.RU ATRA. IT SHOWS THE INTERCHANGABLE PARTS. HOPE that helps.
Dec 18, 2015 | Cars & Trucks
I have a craftsman 24hp model # 917.28970, how do one change/add fluid to transaxle or change. Is a filter required, and if so, which one? What type of oil is required. r
The fluid has been added to the transaxle,at the factory. You do not have to add or service it for the life of the tractor. That is unless,you have removed the transaxle and repaired it in some way. I don't know if this is a new tractor or not,if it is and you are having a problem with the transaxle,and is not working correctly. Try this,Sears fix to this situation is: Move the tractor forward about 5 feet then move it back 5 feet. What this does is,to eliminate air trapped in the transaxle. Sears,claims this may take several times. Why they didn't do this when they first serviced it,is anybodys guess. I'am late in answering your question,anyway i hopes this helps. It you have an Owners Manual,it will state this procedure in your manual. B. Locke
Jun 25, 2015 | Craftsman 42" 24hp Turn Tight Hydrostatic...
How do I replace the clutch?
step 2, remove trans-axle. (im assUming stick shift, as both have clutches.) it's only tedious no tricks or rabbits out of hat.
why not youtube others doing this first. see if its "easy for you" first.
so what does it say there. on that #2 step in FSM.book
answer for STICK shift car.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Drain the transaxle oil.
  4. Remove or disconnect the following:
    • Clutch operating cylinder with hose still attached
    • Gear control cables
    • All the wiring harness clamps and connectors involved with the transaxle removal, tag if necessary for location to aid during installation
    • Ground cable at the transaxle
    • Starter
    • Exhaust No. 1 pipe bolts
  5. Support engine with lifting device.
    • Engine under covers
    • Exhaust No. 1 pipe and exhaust No. 2 pipe
    • Lower stiffener
    • Left and right ball joints from steering knuckles
    • Drive shaft joints
    • Center shaft support and center shaft
    • Dynamic damper
    • Engine rear mounting
    • Engine rear mounting No. 1 bracket with No. 2 bracket
    • Transaxle to engine bolts and nut
  6. Support transaxle with a transmission jack.
    • Left engine mounting with bracket
  7. Remove any remaining attached parts from the transaxle.
  8. Pull transaxle out so as to disconnect the input shaft from the clutch disc and then remove it.
then the install.'
lots more steps and torque settings. RTM?
Apr 17, 2015 | 2006 Suzuki Aerio
Hydrostatic transmission is slipping
This is a serious problem. If you are a serious repair person,you may be able to make a proper repair on a Hydrostatic Transaxle. I have seen this transaxle(Peerless Model, dissembled. There are gears,bearings and a whole lot small parts to a transaxle. I wouldn't want to take on,this task. Call Sears, for a repair appointment or get in touch with another professional repair shop. The problem,you have could be a simple,Adjustment or a major overhaul repair. I would not attempt,to give you any advice on how to make the correct repair. It will require,a repair manual. I know this may not answer,your question. But this is what i would do. Sincerely,Brad Locke
Feb 24, 2014 | Sears Craftsman 46 in Tractor Mulch Blade
How do I add oil to my sears garden tractors transaxle model no. 917.273320
I'am not sure about this model. Craftsman,usually services the Transaxle at the factory. Requiring no further servicing,unless you have a leak developing,then an overhaul of the transaxle has to be made.I would get a professional in a mower shop,to make this repair. Or Sears does this sort of work. I have seen this Transaxle,(A Peerless Transaxle),torn down for repairs. There is more small parts to this transaxle,then anyone other than a Sears Tech or someone trained to do this. Its more work,than a weekend doer can possible do. Hope this is answers your question,Brad Locke DTD. 12/03/15
Aug 06, 2013 | Sears Garden
User manual for sauer-sundstrand transaxle?
This is the only provider of repair manuals on that transaxle on line. I normally get the manuals from the dealer or a local repair shop but this site should provide you with what you need:
http://hydrostaticpumprepair.com/html/sundstrand_hydrostatic_parts_a.html
Nov 25, 2011 | Danfoss Sundstrand-sauer-danfoss...
I had a (!) light come on and the message tire reset displayed where my mileage is displayed
the "check transaxle light," and it's to alert you that your transmission has issues that need to be addressed asap. From what I understand, if the issue is serious, the transaxle (transmission) is probably going to lock into second gear at some point for safety purposes. As fate would have it, there is no real middle ground for repair of these problems. You are God-blessed if there's a faulty sensor cause, which is possible, but unlikely. When transaxle issues occur on these vehicles, 99% of all remedies from dealers or tranny shops would require removal of the transaxle to perform the repair.
Jul 11, 2011 | Ford Freestar Cars & Trucks
Broken release fork on five speed transaxle on a LANOS 1.5 SX
the trans will have to come out, and the clutch components inspected.
Oct 02, 2009 | 1999 Daewoo Lanos
Health & Beauty Logo
76 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
