Some cameras have the choice to take the picture by looking through the veiwfinder or on the LCD screen. check in the menu and set it to LCD if you want to use the LCD
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
I use the hacked firmware 2 years ago. Then Custom Function (12) has been set for Mirror Lock-Up = [On].
Mirror Lock-Up only applys on Single Drive and Timer/Remote but not Continuous Drive mode. So I set to Continuous during normal use and immediately set to Single Drive mode for MUL for some shots that need it, e.g. long tele-lens in dim lights.
It coud be a very common IRIS/Shutter stuck problem...this has been reported on lot of S3 IS & S2 IS cameras... just search for this on web and you'll find a temporary solution also (related to taking battery out in the middle of taking picture during a long exposure (15" in Tv mode), but for more permanent fix you need take it back to Canon service center
There is sometimes a button on digital cameras that turns off the LCD while taking pictures to save battery. Does your camera have a viewfinder? If it does then there might be a button that looks like a little screen or says "disp" or something like that.
I have a similar problem with my Canon S3 IS. Dark/black LCD in
Shooting mode. However, I can view my existing photos in Display mode.
I was about to spend money to get a Panasonic TZ5. Somehow I bumped
into a solution post for S2 IS. Here is the link:
When camera is turned on the viewfinder is black. All other
functions appear to be working correctly. I can view pictures on the
card. I take a picture and it views on the screen and the spec's come up on the botton of the view finder but the viewfinder is 90 black with a bit of blur. Is this the censor or a mirror...?
Is this fixable and at what approximate cost? Would it be cheaper
to replace?
First thing to try is that you didn't accidentally turn off the LCD screen. Turn on the camera, and press the bottom DISP on the back of your camera.
If that didn't work, the next thing to try is to take a picture while the viewfinder is black. Download the picture to your computer, and view it on the computer's monitor. Does this picture also show up as black. If so, then the camera's CCD imager has likely failed, requiring professional camera service to be repaired. If your camera was an S1 IS, Canon would fix this for free:
It may be fixable, but it may be expensive. You also have the option to upgrade your camera through Canon's Loyalty program. I'd give them a call and find out what your options are before going out and purchasing a new camera.
From a similar solved problem:
I have read of this problem (doing research before buying a Canon S2). Apparently it is a bad sensor and Canon will fix it for free if it's still under warranty (otherwise it will cost $119.00).
and
I have the same problem. Just got off the phone with Canon and have to send the camera to them. Repair takes ~2wks. Call them @1-800-828-4040 and follow the menus.
Canon's site also addresses this for the S1 and others (but not the S2). Says heat and high humity can cause a connection to the sensor to come undone.
Hope this helps.
