Question about NTI Backup Now EZ
I cannot access the backup frrom before i had to refresh my compute
I had to basically start from scratch with my computer. I have a backup copy of what was on my hard drive, but I had to reinstall backup now ez (unfortunately I had to install the free version because I could not find my installation disc). When I try to restore the files from my external hard drive where the backup is located, it won't let me because it thinks I have not backed up before. What can I do?
Posted by Bob McDonell on
Jose Diaz
  • NTI Master
  • 2,878 Answers
Try using a restore software like Recuva (free). Run a thorough / deep scan save to another hard drive. This is not the solution you were looking for, but I doubt you will able to retrieve by any other manner if you wiped the system. gl
Posted on Jun 05, 2013
1 Related Answer
shahidkap97
Author Rehman
  • 392 Answers
SOURCE: my computer won't power on after using backup now ez
when it is not compatible with the configuration of the computer,how can windows 7 be installed! you can reinstall the OS but only try xp if it is not compatible!
Posted on Apr 08, 2012
How to I run the back up disk on my everex desk top to restore my hard drive
Components check
1.Acquire the backup disk required to perform the function restoration
Observe the back disk for damages either as scratches or dirt particles. Any oberavable dirt particles would require cleaning with disk device cleaner kit acquirable at retail.
2. Acquire time to accomplish the task activity. Restoration process takes time to intitate, thereafter requiring time for the computer system to install known as restoration.
Restoration process
1.The disk software is places into the computer DVD/R driver.
a. computers would have several different driver compartibilities.
b. the most significant is the driver that would accomodate the restore backup disk
2. power off completely the computer soon after inserting backup restore disk in driver and closing firmly.
3. Power on shortly, the computer should recognise a disk medium in disk driver making possible display instructions from which to initiate the backup process.
important notes
1. the computer may power on without recognising any disks inserted in driver.
a. an alternative procedure accessing the disk at the storage location.
procedures of accessing a disk at the storage area on a computer.
1. select the my computer icon on the desktop. The display menu should provide a list of storage areas the computer is capable of performing
2. clicking in the disk driver location display should open up the backup programs area.
3. the options provided makes possible alteration of the computer, including restoration.
Dec 20, 2010 | Computers & Internet
Tip
How to back up a offline disk folder
<p>Backing up your computer in a folder on the hard disk that goes offline, because sometimes surprisingly simple for the Windows Sync Center. You have a network available offline. Your computer will copy the backup of the hard drive of your computer's hard drive when you're online. The folder will appear as if it were accessible online, because the files are copied to the folder on your computer and then sync when the device is online. <br /> <p><br /> <p>1. Click "Start", "computer" and open the folder with your backup folder. Right-click the backup folder and click on "always available offline." <br /> <p><br /> <p>2. Waiting for the files in the directory so that the copy on your computer available offline. <br /> <p><br /> <p>3. Right-click again on the backup folder and click on "Map Network Drive". Click "Finish". <br /> <p><br /> <p>4. Click Start, Control Panel, System and Security "and" Backup and Restore. "Click" Create Backup.<br /> <p> <br /> <p>5. Select the mapped drive that you defined earlier in the Drive list. Click "Next" and follow the steps to complete your backup to adjust. Click Save Settings and perform the backup. " <br />
on Jun 22, 2011 | Computers & Internet
Formatting a tomtom go 710
Hi, I probably cant answer all of your questions but I might help with some of them. You should be able to access your TomTom 710 without removing TomTom home software from your PC. It should be accesses as a drive through the USB connection in "my computer" on your PC. When a USB device is connected to your PC it appears as an external drive. Therefore you should be able to delete , load onto , or format the TomTom hard drive ( or with some other models the SD card ) as you would a normal drive . ( an example of this is where you might have a camer with SD memory card and relevant manufacturers software on your PC . you might connect your camera to the PC via USB and the camera software on your PC automaticly detects the camera for it to eb accesssed . However , the camera and it's SD card can also be accessed seperatly by going to "MY Compter" and it should also be visible there as an external UDB device / external drive ) . Now .. to another another question . If you do un-install TomTom home , I dont think it will also delete any backup of your TomTom , it will only delete TomTom Home software . ( the word "think" is mentioned because I have never tried this ). Besides that , you can choose in tomtom home , where you want any backups to reside , so you could save backups via TomTom home to a CD for istance. If you did that , then you would have the backup on a CD rather than your harddrive which means you could safely un-install TomTom home knowing that if it also removed any saved backup you would still have the CD with a backup on it. So , to summerise.... If it were me , I would make a backup of the TomTom by simply copying all the files on it by opening the TomTom up as a folder in "MY Computer" , simply drag any files and folders from the TomTom into a folder I have prepaired ( call it for instance "my tomtom backup" ) on my PC . Then I would format the TomTom drive then reinstall the backup and see what happens. If the TomTom still doesnt work properly , I would Format the tomtom again then use TomTom home to obtain all relivant files , then copy only the maps and .MAC files ( these are the authorisation files for the maps ) from my Backup to the TomTom manually ( not from tomtom home ). I would guess that would result in a working TomTom again ... Good luck.
Nov 15, 2008 | Tomtom GO 700 GPS Receiver
Trasfering emails and contacts from Windows Mail to Outlook Express
Hello
you can do it in many ways but I think this is the simplest.
copy addressbook
1. go to file>export>windows contacts
2. and save it to same backup folder on your desktop
copy msg
1. create a folder on your vista desktop(backupmail)
2. start vista mail
3. drag your messages that you want to the XP computer to the desktop backup mail folder you most drag emails you cannot drag and drop folders.
4. when you are done move the folder on a USB stick or something and move it to your desktop on your xp computer.
copy addressbook
1. go to file>export>windows contacts choose CSV
copy your mail account.
1. go to tools>accounts>export
2. save the file in you backup folder on your desktop
then copy the backup folder on your desktop to a usb stick or something to transfer it to your xp computer
your xp computer.
import msg
1. paste the backup folder to your desktop
2. open outlook express and drag and drop the msg from the backup folder on your desktop
import contacts
1. click file import "other addressbook" and choose "text file" navigate to the desktop backup folder and you should find a file to import click OK.
import account settings
1.go to options> accounts
2. then mail tab and click import button
3. navigate to the backup folder on your desktop and choose the iaf file to import
then you are done
good luck hope I helped, get back to me if you need more help.
Sep 18, 2008 | Microsoft Windows Vista Ultimate Edition
File is not accessible. Access is denied message
Hi.
Sorry for the delayed responce. Ok first thing is first. The "files/folder is not accessible" occurs because the program cannot find the files in the place where they should be. for example if you put your socks in a draw and your wife moved it, when you return you wont have axcess to them right :) will basically its the same thing here. What you will need to do is find the default directory of itunes it should be in the Options or tools ir settings menu (I dont use itunes so i am not sure just play around in the program until you find it) once you do you need to search you computer for where the PC Backup put your files ..
click start then search and type the name or piece of the name of a song you know should be there. Once you find it browse to the directory of where the song is located. Click start then my computer then local disk to get to your harddrive. Go to the folder that has the songs and copy them. then paste them into the directory where itunes is looking for them.
Jul 06, 2008 | StompSoft BackUp My PC 2005 (05004) for PC
Softward disc scratched & recovered????
Try to unistall the previous version on your computer before installing the copied software. If you are talking about the basic Futura software, there are no access codes, but if you want to install autopunch or hyperfont you will need the access codes.
Jan 02, 2008 | Singer CE-200 Quantum Futura Computerized...
Very weird...
'Refresh Database' doesn't mean everything is erased. It only means it's writing the progress that you made, onto the computer. It stays on 'Refresh Database' for about maybe 5-10 minutes. It refreshes its database every time you disconnect your MP3 player from the computer. What it does when you disconnect it from the computer is it saves any unsaved changes made to it and overwrites the memory or data.
Oct 28, 2007 | SanDisk Sansa E280 MP3 Player
Computers & Internet Logo
93 people viewed this question
Top NTI Computers & Internet Experts
Lawrence Oravetz
Harrie
k24674
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
