SOURCE: HP c3180 inkjet printer problem
apply two or three drops of 3 in 1 oil to top of the big silver rod (inside printer cover)on which the ink cartridges ride.
UNPLUG RESTART AND Print
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
SOURCE: HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
SOURCE: my color cartridge and black cartridge are brand
well, not to sound obvious but make sure you peel the plastic tape off, and make sure you align the chips on the cartridges correctly.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: Won't print: "remove and check color cartridge"
remove your new color cartridge and make sure you have removed the safety tape on the botton of the cartridge.
