Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Green standby light flashes about 40 times the the Lamp red light flashes for 30-40 times
When I turn on my tv the green standby light flashes about 40 times then the Lamp red light starts to flashes for about 35 times the the standby light goes soild red,
Posted by George Padilla on
5 Related Answers
Anonymous
  • 179 Answers
SOURCE: standby light flashes
the lamp thermal sensor is probably bad...you ma also have a lot of dust around the lamp fan..there is a service kit for this problem.
a1137954a..you must clean all the dust from the fan above the lamp or replace it.
Posted on Nov 28, 2007
Anonymous
SOURCE: Intermittent lamp turn off
your lamp is fried just change it i did the same to mine and it works just like a charm
Posted on May 28, 2008
Anonymous
  • 203 Answers
SOURCE: Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Posted on Sep 14, 2008
electroman
  • 1039 Answers
SOURCE: TV won't come on. Standby goes green,then goes red blinks 3 times
3 flashes means the lamp door is not on correctly or the lamp door switch is broken.
Posted on Apr 26, 2009
Anonymous
SOURCE: power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
Posted on Feb 21, 2010
1helpful
2answers
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
The tv repeatedly turns on then off
First area to check out is the power supply of the set.
5helpful
3answers
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
2helpful
2answers
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
1helpful
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
3answers
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
6helpful
Standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
2answers
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
Open Questions:
See all Sony Grand WEGA KDF-60XBR950 60" Rear Projection Questions
Top Sony Televison & Video Experts
Jaime Hernandez
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
