When cycle starts water fill half way up door, then beeps. If you hit power button it drains and shuts off.
Replace the analog level pressure switch, it sounds like it is bad, and the machine's overflow switch is the only thing stopping the fill from flooding your house... Whirlpool Washing Machine Pressure Switch WPW10239066
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
SOURCE: Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Hello & Welcome to FixYa
FL error indicates flood condition and is caused
due to any overfill condition that occurs inside the washer. To clear the
display you can press and hold the STOP/CANCEL button. Usually this error is
caused when overfill switch trips due to excessive water in the tub. You can
also try to clean the drain hose and check the water inlet valve. Please get
back to me if you have any other questions.
Kevin
