Vizio GV47LF Television Logo
Anonymous Posted on Jun 04, 2013
Horizontal Lines on screen
I have tried HDMI, both component, and A/V and I am getting horizontal lines coming through the screen. When I first turn the TV on it displays the blank blue screen fine with out any lines. Any ideas?
Level 3:
Top Expert:
  • Vizio Master 76,851 Answers
  • Posted on Jun 04, 2013
Vizio Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007849
Points
237762
The ABL circuit to main logic board should be checked. It is a skilled work. In most cased, this board might need replacement. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Testimonial: "I have worked on many dlp Mitsubishi Tv's and have fixed one LG LCD that had bad capacitors. I am in no way an expert but like tinkering on TVs for myself. I do not have the tools to test equipment on the TV, rather I would only be able to swap out parts if I knew for sure what the problem was. Are you referring to the main board on the TV that would have the inputs on it? Thank you for your help."
wisiny.com
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Vizio Master 848 Answers
  • Posted on Jun 05, 2013
wisiny.com
Vizio Master
Level 3:
Renaissance:
Answers
848
Questions
0
Helped
454073
Points
4753
In most case ,the panel of your tv is damage,need change or repair the tab of your panel.so you need take your rv to experienced repairer to solve this .thanks,if you need any boards you can view wisiny.com
5 Related Answers
Anonymous
  • 116 Answers
  • Posted on Apr 15, 2009
SOURCE: Wii remote hit the tv, and it's cracked from the inside, fixable?
The LCD panel is bad. Too costly to replace, though.
Anonymous
  • 1077 Answers
  • Posted on Jun 13, 2009
SOURCE: We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Chi Chu
  • 8457 Answers
  • Posted on Oct 19, 2009
SOURCE: tv has blue/white lines going through the screen
Ur main video board backlight,is dying must be replace to solved this prob.
Anonymous
  • Posted on Nov 12, 2009
SOURCE: horizontal line at top of screen in any hd format.
Get into the TV menu and locate the H (Horizontal) and V (Vertical) picture options. . .increase the V until line at the top is gone.
Chi Chu
  • 8457 Answers
  • Posted on Oct 12, 2010
SOURCE: Have horizontal green and purple/pink
This tv have problems with it Tuner signal board.Take it back,where u buy it.Ask for a new tv replacement.U should not have any colors scrolling lines in the LCD screen panel at all.
Samsung UN55FH6030 55" Full HD Flat TV. There are horizontal lines on upper half of television screen (even if nothing is connected).
There are some ideas here, but you are likely to need a service centre. Also help in the videos.
Samsung TV Has Horizontal Lines On Screen
iFixit https://www.ifixit.com > Wiki > Samsung_TV_Horizo...
Your Samsung TV has lines running across the picture. They mess everything up. You don't need horizontal bars in your view. We will walk through some things ...
Lines on Samsung TV screen
Samsung https://www.samsung.com > ... > TV & AV
Apr 13, 2023 - Troubleshooting. 1 Check whether the lines on the screen are moving or permanent. 2 If the lines sway, check the input source (HDMI 1, Video, ...
3answers
Two horizontal lines appeared near bottom of screen
You can spend $300 to $500 fixing this or just do the best thing most cost effective thing and replace the TV.
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
I have horizontal lines across screen have to turn on couple times til it comes on voice will work but screen not on turn off on then pic an sound with lines across screen
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
I have a LG 42lh30 it's only about 1 1/2 years old and recently 1/8th of the screen in lighter than the other with really little lines through it, like unmoving static. If we plug the CP in via HDMI it...
Hello. Horizontal lines on the screen are virtually NEVER caused by a bad T-con board. Horizontal lines indicate a defective LCD panel (screen). It looks like your next step is to replace your TV.
For past two days i'm getting one thich horizontal lines on my samsung 34 inch LCD TV
Vertical lines are usually indicative of TV failure while horizontal lines are generally an input failure. Try switching to a different input, use a different cable (HDMI vs. component), or try inputting through DVI or VGA. Easiest solution is to replace the current cable you're using.
Three coloured lines appered on the screen - no picture
If there is no picture and 3 vertical lines in the center of the screen, stop. Turn off TV. You have no horizontal deflection happening. Lines will burn into crts and be permanently visible after repair.
No horizontal deflection is caused by Horizontal sweep circuit failure, maybe flyback transformer and associated components. More than a simple do-it-yourself repair.
easyab
2answers
I have horizontal lines on my Mitsubishi 62525 dlp tv. it does this on cable and component sources (only ones i have hooked up). When you pull up the tv menu these lines do not appear and also the lines...
Bad capacitors. On my set HDMI looks clear, but component inputs have moving horizontal lines. There's a guy named Tbully on AVS forum that did a PowerPoint presentation that will point you to the capacitors to change. Sorry I don't have a link at this time.
Horizontal lines and color problems?
this could be a format issue. When you change the channel do the lines go away ? If so try to go into the cable box (assuming you have a cable box) and reset your formats and exclude the format causing the lines.Make sure if your using component cables all colors match up.If this does not fix it replace your component cables/hdmi.All else fails unplug your TV wait 5 min. and plug it back in. Hope this works for you.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
