Question about OKI MICROLINE 321 Turbo Matrix Printer
Printer prints one line, then alarm light comes on and stops printing.
Our printer prints out the first line, then stops, the alarm light comes on and the pitch changes from 10 to PROP. Everything is connected. We have tried unplugging power cord, and cable and plugging back in. HELP!
Posted by BJ McCleary on
zeeshan ali
    New Friend:
    Problem Solver:
  • 11 Answers
Sir the printer is giving line because the cartiage or toner is not of good quality so it does not melt properly and produces line while the alarm comes and stop printing is due to the problem in charging cathode or gutter
Posted on Jun 03, 2013
3 Related Answers
Desmond Pillay
  • 40 Answers
SOURCE: Printer Alarm Light
Your carriage motor could be the problem.
Dezzi
Posted on Jan 04, 2008
Anonymous
  • 2961 Answers
SOURCE: Printer font default
OKI printers tend to only print in the font size that you give it in the print options or the softwares printing properties that you are using, you will find that it just indicates the font size being printed if it changes back, this means it's set to 10 in the print properties or the actual programme print setting.
Posted on Aug 03, 2007
Anonymous
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
2helpful
Canon mp250, not printing. Print screen says "creating print data" and freezes there.
This sounds like an internal memory problem and I don't have a workaround. Before you give up, try this technique to reset the printer to factory. They are great printers once you learn this reset technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
1helpful
2answers
The alarm light is on and it won't print
Check the back of the printer. Open up the back door. There is a barely visible 2nd door which you need to open. Check to see if there is a paper jam behind this 2nd door. Often this is the problem and clearing this back paper jam will clear the red alarm light.
Brothers HL 1240 Alarm light on
Pull the drum out the front door, remove the toner cartridge and check for any paper and remove it.
Make sure there is toner in the toner cartridge. Look at the lights on the printer. Look at the labels beside them. The label "Toner" will have two lines going to two lights. If those two lights are on when you try to print, you are out of toner. But a now toner and install it in the drum. Install the drum back into the printer.
If not, look at the drum. At the rear top is an opening across the whole drum. Look inside it, you will see a metal grid. That grid must be clean or it will cause small sparks. These sparks will cause a false toner empty error. Buy a can of compressed air from Best Buy (or wherever). Use this compressed air to blow clean the grid. Move the small blue tab at one side of the opening ti the other side and back again. Reinstall the drum and try printing again.
If neither of those help, write back and let me know what lights stay on when the printer stops.
Alarm light remains on. Printer will not print
There are Post Script (PS) and PCL fonts (i.e. PCL5)
Try installing PS Font types for this printer.
Adobe uses the PS Font types.
I hope this helps.
4helpful
2answers
Printer alarm Brother 1440
Use the following steps to perform a Factory Reset:
  1. Turn the printer off.
  2. Hold in the circular button on the front panel of the printer.
  3. Turn the printer back on.
  4. When the DRUM light is lit by itself let go of the button.
  5. Hold in the circular button on the front panel again.
  6. Once the Alarm light comes on, let go of the button.
let us know if this works.
1helpful
2answers
Alarm
look in the manual for alarm codes, on? flashing?
possibility something wrong with the carriage, this is the black piece where the ribbon sits on, there are gears in there that will break, very common
1) take out ribbon and print, if it continues to print a few lines without alarm, it's a bad ribbon.
2)turn off printer and move the carriage my hand from side to side, should be smooth, if you hit a bump or tick, it's the carriage.
OKI MICROLINE 321 Turbo Matrix Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Ekse
Alvin Barnabas
Alvin Barnabas
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
