Question about Seagate Backup Plus STCA3000101 - Hard drive - 3 TB - external deskt
Cannot install Dashboard 2
I cannot install Dashboard 2 on my new external hard drive. During installation, I get the error message "Mocrosoft VC Redist 2010 SP1 (x64) has failed. Setup will now exit." I'm running Microsoft Windows 7 Professional 64-bit SP1. All updates are current
Posted by Gilbert B. Furst on
Jose Diaz
  • Seagate Master
  • 2,878 Answers
Visual Studio is not an update, but a MS suite that will update after install.
http://www.microsoft.com/visualstudio/eng/downloads#d-2010-express
Posted on Jun 05, 2013
Msvcr100.dll missing I CAN NOT RUN TAKEN5 GAME IN MY FUJITSU
this is your directx problem. the directx plugin which is required to play tekken 5 is missing or not installed in your pc. to fix this problem, you have to install latest directx or update current directx version to latest version. updating directx may take nearly 150 to 200MB.
Apr 11, 2013 | Computers & Internet
Many errors after installing a new HDD on samsung R480 laptop
HI , there ,
Did you back up your data ? if so just recconect your old hard drive if you didnt format it and run windows go to my computer right click and click properties scroll down the the bottom and you should be able to see your product key jot that down and reconnect your new hard drive install windows and enter the product key.
as for the windows updates look up the error messages , you might have to copy the folder and delete the old oneas sometimes the donwload folderr gets corrupt.
Hope this helps .
Dec 29, 2012 | Samsung R480 Notebook
Error code 80080005
Is your windows updates disabled? Is your anti virus up to date? Do you have a Malware program, updated? If you do not have MALWAREBYTES download and install :http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, may take hours, depends on HDD size. Delete ALL RESULTS. I don't know your OS? Vista? win7? 32? 64? Her is a standalone windows update for both 32/64:
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x86.exe or
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x64.exe
Nov 19, 2012 | HP TouchSmart Computers & Internet
Trying to reload Windows OS. Run into
From another computer build a msdos floppy disc, yes floppy disc.
I believe you computer accepts floppys does it not? and i also asume you are running xp, you can try running the startup disc and trying to check disc, but if you cannont procede, i would opt into downloading another copy of the windows and try installing through that method. If the disc dosent load, and you get that error message of the bat, another step will be waiting for you.
May 26, 2012 | Dell Dimension 8400 PC Desktop
For some reason when I run the smartware to unlock my drive I get the error message "The application has encountered an unexpected error and is now exiting." I've used this drive for over a year...
Update the software again and unplug for 30 to 30 seconds. Unplug the USB from computer and External Hard Drive. Unplug the AC Adapter. Replug everything, the correct driver will be installed
Jan 02, 2011 | Western Digital My Book Elite 2TB External...
Hi there! Yesterday I was installing Windows XP
Sorry to hear your having issues installing the OS.
There is two problems your facing one is the disk is so scratched that the system can not read the disk or the hard drive has bad sectors or clusters which are failing when being written to.
You have two options to fix this one is to make sure the cd is clean an or replace your hard drive.
General disk read error message tend to be from hard drive cylinder's.
Nov 05, 2010 | ASUS Computers & Internet
Hi, I get an error message when I try to connect and install a Maxtor 500 GB external hard drive to my computer. The message reads "the device cannot start (Code 10). Can you assist?
What is the error message you get?
What OS are you using?
Depends on your hard drive, some computer commonly ask for a driver when you plug something in it. might as well try reading the manual of your external hard drive, if it doesn't require a driver, then the problem "might" be in your operating system and/or in your computer.
Sep 26, 2008 | Computers & Internet
Seagate Backup Plus STCA3000101 - Hard drive - 3 TB - external deskt Logo
454 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
