Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Not drain water
REMOVED CAP... TOOK OUT OBSTRUCTION AND STILL WONT DRAIN
Posted by CHRISTOPHER on
  • Bosch Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jun 03, 2013
5 Related Answers
Anonymous
  • 1185 Answers
SOURCE: Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
Posted on Jun 18, 2009
Anonymous
  • 9 Answers
SOURCE: washing machine is not draining
Your drain pump is probably dead. Advice: do not believe anyone who tells you that it is a pain to replace on BOSCH! I just did it myself in less than 45 minutes and thereby saved about $200.
You need to order the part-> go to the BOSCH website and identify the exact model and part number for your machine. I ordered mine from www.appliancepartspros.com/Bosch-Parts.aspx.
The part arrived at my home this morning-it took 2 business days. I called to double check I had the right part and the CS person was very nice and helpful.
Then, beating the odds I did the following with just a pair of pliers and a screw driver:
1- unplug the washing machine (of course)
2- drain any water that could be left in it using the small black drain hose located behind the front bottom door (probably on the right)
3- lie your washing machine on its back-put a piece of wood long enough to cross the width of your machine and it will save your fingers- you will need some thigh and **** muscles as it is a little heavy (but I am a woman and did it without help)
4- remove the bottom front panel of your washer (2 screws)
5- remove the screw holding your pump (above the filter)
6- lying down on the floor, unplug the wires at the back of the pump"s motor
7- using your pliers loosen the braces that hold each of the 2 hoses, and slide them down along the hoses (easier this way)
8- take out the hoses- the pump will drop into your hand
9- place the new unit by screwing it to the front of the machine's casing
10- plug back the wires
11- reposition the hoses making sure that the braces are tightened around the hose + each of the 2 plastic tubes that stick from the pump
12- tilt your machine back up
13- plug your machine
14- you are ready for your first load adn have saved $200 :-)!
Posted on Jul 27, 2009
Anonymous
  • 14 Answers
SOURCE: water wont drain from wash. Wont spin or drain
Something will be jamming the drain pump (no surprise there).
Some Bosch w/m's have a base plate, some don't.
Pull the w/m forward & tip it back against the wall at >45 degrees - should balance there easily. See if you can get underneath (inside).
If so, (power disconnected), remove the bottom kick plate area, and drop the drain pump back internally & down. Remove the wires & pipes (slowly, if there is still water to drain), and remove the pump. Dismantle it & remove the obstruction.
If there is a base plate, try for all hell to get the filter cap off.
Otherwise, you will have to put the w/m on its back, and unscrew the base plate (often, not an easy feat, as the screws are very still & jam).
Then follow above instructions.
Posted on Dec 12, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Bosch Maxx Classic wont drain
The correct procedure for removing the filter is to unscrew it anti clockwise, and pull it out.
If it does not come out, then it is possible that there is something stuck in the filter, or the filter seal has swollen
As you unscrew it, try moving it from side to side at the same as you are pulling on it, then screw it back in again, and try the same procedure.
Hope this helps.
Posted on Dec 21, 2009
mike cooper
  • 884 Answers
SOURCE: My Bosch Exxcel 1200 wont drain and wont spin on normal cycle. It shows an F18 fault
If hoses clear and filter not blocked, can only be pump fault
Posted on May 19, 2012
Cabrio washer code Ld
Top load washer Ld is a long drain the drain pump is connected to the tub remove the water pull the basket there in a round cap covering the drain port removed screw and cap look for and obstruction go to youtube video will show you how to remove basket
Aug 31, 2014 | Whirlpool WTW6200S Top Load Washer
Asco W6221 won't drain. Sounds like the signal is being sent, but won't continue the process. I've cleaned out the drain pump and that seems to be working;as best I can tell(took cap off, water on the...
CHECK UR WATER PUMP PROPELLER FOR OBSTRUCTION, CAN U TURN THE PROPELLER BY HAND? CHECK FOR BLOCKED HOSES, IF PUMP IS ELECTRICAL TYPE THEN CHECK WITH A METER
Dec 17, 2013 | Asko W6221 Front Load Washer
Not drain water
This video will show you how to clean the pump and how to find the fault on a washing machine that won't drain or empty the water away on Bosch, Neff or Siemens. Please remember to subscribe to our YouTube channel for all appliance tutorials
a thumbs rating is appreciated for answering your free question.
Jun 02, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Whirlpool Duet washer shuts off when tub fills with water
First, does your unit attempt to clear the water from the drum at all? That is, do you HEAR the drain motor engage and attempt to pull water out of the drum? I had to do a little more than clear the drain filter to fix mine. The drain filter was clear, but my Duet still wouldn't clear the water from the drum. When I pulled off the drain filter cap, I got a trickle (not a GUSH as you normally would) of water, indicating that the problem was further up in the line. However, first confirm there's nothing obstructing the exterior line clear thru to the drain filter. And I have to ask, does ANYTHING drain from the tub-- that is, is NOTHING coming out (in which case it is probably your drain motor), or is it just coming out slowly (indicating an obstruction prior to the motor)? Slowly means you should backtrack from the drain filter to the tub basin. On my unit, there is a black rubber hose that comes off the drain filter and leads to the tub collection basin. This hose attaches with a hose clamp that is easily removed with a set of pliers (in all honesty, in fact, it is considerably more difficult to put it back ON). When you remove it, you'll notice a float at the beginning of the black rubber hose. Clean out around it. Then, (and probably a more likely cause of an obstruction) reach your hand up into the tub basin and feel around. Mine yielded about 5 cups (no kidding) worth of yuck that was causing my drain issue that, when removed, completely solved the problem.
Mar 03, 2013 | Whirlpool Clothes Washer Rotor Position...
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
Spin cycle isnt not working
The spin cycle is reliant on the drain pump removing water from the tub.
It is a common ocurrance of objects (ie hair pins, pegs, coins etc) to be mistakenly washed through the cycle. Washing machines will often flush these objects down through the drain pump, and get caught in the little propeller of the pump.
So, it is imperative that you inspect the drain pump first and remove any obstruction within the drain pump cavity.
Turn machine power OFF at the wall and remove the power plug.
i) place an empty bucket on the floor
ii) lower the drain HOSE into the bucket - gravity will cause the water to drain into the bucket. Empty the bucket. Perform this procedure until all water has been emptied from the bowl.
iii) move the washing machine out from the wall, to gain access to the drain pump (usually a large screwcap). Place a large towel on the floor, under the screwcap - this will catch any remaining water that escapes.
iv) unscrew the drain pump cap and withdraw the cap. This cap may also contain a filter, so remove any lint/objects from this filter.
v) with the pump cap/filter removed, look inside the pump cavity and remove any visible obstruction from the impellar (little propeller thing). Then, with your finger, turn the little impellar in both directions - if you feel a 'rubber band' like resistance, then the drain pump may be ok at this point.
vi) remove all wet clothes from the machine bowl.
vii) re-assemble the drain pump cap/filter and secure it in place. Install drain hose back into your laundry tub. Plug machine back into power.
viii) fill the bucket with water and pour water back into your machine's bowl. Repeat with a 2nd bucket of water.
ix) manually select and operate SPIN cycle on the machine. Observe if drain pump functions correctly and empties water from the bowl. If yes, then you have resolved the problem.
If your pump has been cleared of all obtstructions but your machine will still not empty water from the bowl, then a full diagnostic will need to be carried out by an authorised service agent to determine which component has failed.
Let me know how you get on.....
Good Luck..
Oct 31, 2011 | GE Washing Machines
How to i flush a radiator on a 2000 expedition and what tools do i need?
you need, knife/ gear clamp,screwdriver /nut driver (for gear clamp) and garden hose
with water pressure hook up hot water is better
you can buy a can or to of rad flush but dishwasher soap works good (it wont suds up )
also rad flush kit with garden hose addapter (most kit are compatable)
1-drain existing coolant in container for recycling
2-locate heater return hose to block and cut to installed flush kit addapter
always better to reveres flussh system with engine off and rad cap removed
drain valve closed hook up garden hose and run hot tap water true system
it will eventually cove out your rad cap (surge tank) until it runs clear
know sut off the garden hose add your cleaning additives installed rad filler cap
run engine per direction on can or 10 to 15 min. sut off engine removed filler cap
open drain valve on radiator and drain out system open water from garden hose
run water until clean water run true shut off garden hose and removed cap off with
cap supplied with kit let system drain completly . repeat cleaning operation until
water runs clear
add 1 jug of concentrated coolant (will mix with ressidual water and finish filling
system with premix used recomended coolant only for your engine your freeze
point of new coolant should be above spec and will be fine
do not used pure concentrated coolant only .your ownners manual spec section will
give capacities system will hold
Apr 03, 2011 | 2000 Ford Expedition
ND...our samsung won't drain and spin cycle doesn't help
I had similar problem. It would wash but not spin and drain. Spin would only happen when there was no water inside (I removed it manually.) If it spins when empty of water then it could be the outlet from under the drum to the exhaust pump is clogged or the pump itself is clogged. I found $3 in change and a bunch of plastic tags etc.. Remove the bottom panel and unscrew filter (bottom right) check for obstruction. Also tilt machine to side and undo rubber hose from drum to pump to check for obstruction.
Jul 01, 2009 | Samsung WF337AA Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
59 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
