HP LaserJet 4350 Printer Logo
Question about HP LaserJet 4350 Printer
Don't want job page to print every time we print
It always prints a cover page with job#, date & time & is wasting my paper!
Thanks.
Posted by chasem813 on
Drew Lendabarker
  • 37 Answers
Right click on the printer icon, go to Properties, on the Advanced tab click on Separator Page and delete whatever is in the box. Click OK and OK. The seperator page will no longer print.
Posted on Mar 27, 2009
Anonymous
    Problem Solver:
  • 10 Answers
You can turn off print summary by accessing printer menu , one of the function
Posted on Mar 21, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
2helpful
I've been using OKIDATE MICROLINE 320 PRINTER at work. I was printing something and I realized that I was printing the wrong page so to stop printing, I simply turned off the power and waited....
You would have to cancel the current print job from your computer for it to stop. Assuming you have access to a computer that is connected to that printer, you will have to find that printer by going to Control Panel > Printers and Faxes > Oki ML 320 then right click, select "See What's Printing" and cancel Current print job (I am also assuming you are using windows). I really hope this helps, if not add a comment clarifying your question, thanks.
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
My print jobs always print the last page as EOJ. This is wasting paper and is driving me up a wall. How do I fix it?
Sorry to read about your problem, I hope this helps you out.
You system does not provide a way to stop the EOJ page....
most network printers do not allow that function
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
I would like your advice as to how to stop a Printing job before completion on Canon LBP2900B I have been wasting A4 paper because the full job has to run its course even though I wish the job to...
when printing, you may press the CANCEL button on the printer, right-click the printer tray icon and click view print jobs, then cancel a print job before it completes. you may also want to try specifying only the pages you want to be printed instead of selecting all pages to avoid unnecessary print outs. hope this helps and let us know how it goes.
1helpful
My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
It prints gibberish before the print job.
I have had this happen before, this could be you need to change the drum kit on the printer itself, check the indicator light.
HP Business Inkjet 1200 printer always prints the Alignment Page
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
2answers
Not printing, making me crazy
A paper jam has occurred. To solve the
problem, see “Clearing Paper Jams” on
page 6.3.
• The front or top cover is opened. Close the
front or top cover.
• There is no paper in the tray. Load paper
in the tray.
• The waste toner container is not
installed or full. Check the container.
• Your system has some problems. If this
problem occurs, contact your service
representative.
  • Also i can indicate that the Toner Cartridges are empty and need replaced with Genuine Samsung Cartridges
15helpful
8answers
I have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Clive
Clive
Ben Johnson
