Question about Garmin nuvi 260W GPS Receiver
My Garmin nuvi says ''maps unavailable''
When I try to find an address, I only get a message that says:
No detailed maps found that support routing. The nuvi cannot be used without them.
Posted by jemrud on
Harry
  • Garmin Expert
  • 343 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
The GPS device is missing it's unlock code
The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Posted on Jan 28, 2010
2 Related Answers
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Posted on Aug 20, 2009
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Posted on Feb 28, 2009
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garmin nuvi 200 it say no detailed maps
my garmin 200 nuvi say no detailed maps found that support routing
May 21, 2010 | Garmin nuvi 200 Car GPS Receiver
- Jim
Jul 11, 2009 | Garmin nuvi® 200 Car GPS Receiver
"No detailed maps found that support routing".
Please click on this link to obtain more information on this problem:
- Jim
SHARCNET-USA
Feb 20, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
No detailed maps found. Help! Please
my email address is ada @ ebucksmail.com.
Can u please help with my sons nuvi 200 that shows no detailed mapsfound. Thanks A Million, Ada.
Jan 22, 2009 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
2,199 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
