Question about Apple iPod touch
DEAD IPOD 8GB
MY Ipod went thru the washing machine and dryer now nothing comes on and wont charge. Any solutions?
Posted by al0215 on
Mel Neilsen
  • 342 Answers
You can disasemble the iPod to see if there is any visable water damage. If there is and you want to replace it, you can go to www.ifixit.com and order the appropriate parts there. Also at the bottom of this entry you will see another web address. This is where you can watch free iPod repair video's. :)
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
http://fixyouripod.weebly.com
Posted on May 19, 2009
  • Mel Neilsen
    Mel Neilsen May 19, 2009
    Ah I did not realize that this is an iPod touch issue until just now I apologize. I have not been able to discover a way of self repair with this model yet.
My IPOD NANO 8gb 3rd gen just hung up after charging it normaly.How so I fix that?
Tips:- Charge you Apple ipod with original Charger which comes with Apple ipod box as a accessories.
Solution:- Charge it will original charger & Connect this ipod to iTunes & just restore the ipod or update iPod software to latest version.
Feel free to ask your further queries to us.
After that all it will work fine 100% .
Thanks.
Happy to help you.
Apr 25, 2010 | Apple iPod nano MP3 Player
My ipod wont turn on or charge, it wont do anything
charge your player and try again if not works then replace
battery of your player it may be dead.
Dec 25, 2009 | Apple iPod nano
8gb nano ipod not working
remove screws, pull apart, let air dry or try drying with hair dryer. don't recommend pulling screen apart. There is several layers of the screen. It is hard to remember what order the screen layers go. But still take apart for better drying.
Feb 02, 2009 | Apple iPod nano
Ipod nano went thru washer, now won't work
I did the exact same thing to my iPod nano 3rd gen. I discovered it by the noise it made in the dryer when it fell out of the pocket. Clack! Clack! It seemed dead, but it made a full recovery. What I did was put it on the dashboard of my car for a couple of sunny days to dry out, recharged it, and it was fine. If you have particularly hard water, maybe you'd want to try dipping it in some distilled water just to get rid of any mineral residue before drying it out. I'm impressed with how tough these dudes are. Good luck.
Ipod nano 8gb won't turn on
This is a common problem when the battery dies. There is no power so iTunes will not recognize it and the iPod will not come on. If you connect it to a wall charger, and you see the iPod come to life, then you know that it is the battery.
Yes, the batteries do die and usually do after 2 years, sometimes sooner depending on how much use it has had. Batteries on these are replaceable, but they are soldered to the circuit board, so they are not replaceable by ordinary folks. Good news, Apple and other companies will replace them for about $60 or you can trade it in on another and get a 10% rebate, or you can sell it on ebay and get some money to buy another. People buy them for parts. Hope that helps.
Sep 30, 2008 | Apple iPod nano
My son left his ipod in his pocket and it went through the wash.
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
Apr 12, 2008 | Apple iPod nano
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
8 GB Ipod Nano went dead and now won't charge
does it work on the charger? if not, then contact apple or your dealer for more assistance or repairs.
If it works on the charger, plays music and so on, your battery is probably dead and you need a new one.
Mar 24, 2008 | Apple iPod nano
Charging problem
http://www.apple.com/support/ipod/five_rs/
if you connected the ipod directly to 240v its dead and done.
If you need more asistance, let me know. Good luck.
Mar 16, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod nano wont do anything
I think your ipod is dead. This happened to me to. I was listening to it when I arrived at my destination, and I thought I turned it off and I put it in my pocket. Later that day when I went to listen to it, it wouldn't turn on at all. Aparently, it had stayed on. Hold the pause button for five to ten seconds. The apple symbol will appear on your ipod. Immeadility put it in your docking station before it goes away. Your ipod will turn on, and itwill start charging.
I hope this helps. Please rate my solution.
Mar 02, 2008 | Apple iPod nano
Apple iPod touch Logo
173 people viewed this question
Top Apple Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Geoff
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
