My laptop is having a funny five! For some reason my Hp530 (had it for about 7 years) it wont load to home page it just says: "Non-system disk or disk error replace and strike any key when ready" please help, am losing the will. Thanks a bunch peeps :)
  • 369 Answers
Please turn off the computer, start hitting F8 at the start-up and then choose last known good configuration. If this does not work, choose Safe mode options.
If still does not work, please try to restore the computer to factory settings. You can try to hit F11 or F10 at the startup to initiate recovery. system recovery will delete all of the data/file and software installed on the computer.
Posted on Jun 02, 2013
5 Suggested Answers
Anonymous
SOURCE: compaq evo 610
Turn it all the off. Then pull the hard drive out and put it back in again. Now, put your system disk (Win XP?) into the drive and turn the laptop on. It should do something else now. I have had this happen on several laptops I have rebuilt and it takes patience to get them started sometimes.... I have managed to load XP onto all of them eventually!
Hope this helps
Posted on Apr 04, 2008
Anonymous
  • 333 Answers
SOURCE: non- system disk or disk error
This means it cannot read the HDD in the machine. Have you left a disk in the CD/DVD slot or a usb drive in one of the usb ports?
You may have to insert your operating system disk in the CD/DVD drive and do a repair installation.
Posted on Apr 06, 2008
Anonymous
  • 230 Answers
SOURCE: non system disk or disk error
get a new hard drive and reinstall software + OS
Posted on May 23, 2008
Anonymous
  • 47 Answers
SOURCE: Please help me with my COMPAQ ARMADA 1700
Double check to make sure there is no floppy disk or CD-ROM disk inserted when you boot. If there is definitely no floppy or CD, your hard drive may have crashed or been corrupted. You can try installing Windows again, but it might not work if your hard drive is faulty. If it's faulty, you'll need to head to the local computer repair shop or have a geek friend help get and install a new one, then reinstall Windows.
Posted on Jun 11, 2008
ultimitloozr
  • 489 Answers
SOURCE: non-system disk or disk error
Your laptop isn't seeing your hard drive to boot up the system. You need to replace the hard drive.
Posted on May 29, 2009
Need radio code
no year, ouch.
posted now, 23 times. here it is, again. (im gunning for a new record)
pretty much all cars, newer
De'ja' vu , all over again. (LOL) RTM
RTM read the operators manual, its all there, here is a direct quote.
true for all cars, really all modern cars, 2001 to now. about. read your operator guide)
quote 23
2008 opr.guide.(lost it, huh?) Accord. non satellite Radio. NAV system. , all cars.... 2008 direct quote.
Quotes:
Your vehicle's audio system may disable itself if it is disconnected from electrical power for any reason.
To make it work again, you must enter a specific five-digit code with the preset buttons.
Because there are hundreds of number combinations possible from the five
digits, making the system work without knowing the exact code is nearly impossible.
You should have received a radio code card that lists your audio system's code and serial numbers. {glove box find}
It is best to store this card in a safe place at home. In addition, you should write the audio system's serial number in this owner's manual.
If you lose the card, you must obtain the code number from your dealer.
To do this, you will need the audio system's serial number.
If your vehicle's battery is disconnected or goes dead, or the radio
fuse is removed, the audio system will disable itself. If this happens,
you will see ''ENTER CODE'' in the frequency display (on the screen on models with navigation system) the next time you turn on the system.
Use the preset buttons to enter the five-digit code. The code is on the radio code card included in your owner's manual kit.
When it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over; complete the
five-digit sequence, then enter the correct code. You have 10 tries to enter the correct code.
If you are unsuccessful in 10 attempts, you
must then leave the system on for 1 hour before trying again.
The system will retain your AM and FM presets even if power is disconnected. {only on newer cars'
General information on Honda and DIY:
{the code can be obtained from any Honda dealership (you must give him/her your radio serial number (sticker off radio)"}
or any locksmith with a license from..NASTIF
Honda1 ServiceExpress (Same info as ISIS)
Acura ISIS (Dealer version w/ advanced search)
http://nastf.org/i4a/pages/index.cfm?pageid=3462
Dec 29, 2013 | Honda Ridgeline Cars & Trucks
Enter radio code
no year>?
posted 21 times... now. (just me)
go to Honda dealer.... short answer or
now long, (lost operator guide, ?
21st time....
true for all cars, really all modern cars, 2001 to now. about. read your operator guide)???
quote 21st time.... and counting (searches do work)
Quotes:
Dec 20, 2013 | Honda Fit Cars & Trucks
Need radio code s/n 25038 129
ive now posted this 18 times. now.
here it is in full again, verbatum. again. RTM,
lost your operators guide, well here is the section.
quote and adds.
quoted 18 times. (funny how searches never work,./..........)
and par, for course all newer cars.
Quotes:
Dec 16, 2013 | 2006 Honda Civic Coupe
Navigation needs pin
POSTED 19 times now (rad or nav) use search,
quote 14
Quotes:
http://nastf.org/i4a/pages/index.cfm?pageid=3462ex.cfm?pageid=3462
Dec 16, 2013 | 2011 Honda Pilot
No sound from speakers
all newer hondas, and acura. (works the same way)
open glove box take put operators guide, read radio page.
here is the quote. (posted many times)
quote
2008 opr.guide.(lost it, huh?) Accord. non satellite Rad.
Quotes:
Because thereare hundreds of number combinations possible from the five
It is best to store this card in a safe place at home. In addition, youshould write the audio system's serial number in this owner's manual.
five-digit sequence, then enter the correct code. You have 10 tries toenter the correct code.
Nov 26, 2013 | 2007 Acura TL Sedan New Cars
Power outlet radio blown fuse reset self
your radio may need its code put in to work again.
Oct 13, 2013 | Acura Cars & Trucks
My 2002 Honda Odyssey recently needed a jump start. Now my radio has a "C" on it and will not start. I tried using the radio code, but that didn't work either. Any suggestions?
the radio wont start? you meant PLAY.
that is because you lost the secret code, the opr. guide warned you .
the new car came with a green radio code card. sure lost.
so where did you get your code. ib bet off the silly internet. the web of lies? sure.... ????
the nice honda book (glove box,) shows you how to back up (paper) the day one code, goes i wish my jeep had that.
it says that and if posted the full pages, here 27times, on this forum
just for honda's , since they are so friendly that way, allowing you to do that....
quoted 28 times now: see below.
2008 opr.guide.(lost it, huh?) Accord. non satellite Radio. NAV system has own code. , all cars.... 2008 direct quote.
Quotes:
or honda.
Aug 05, 2013 | 2006 Honda Odyssey
Enter code
to what, can i buy a noun for $1, says vanna white?
buzzzz no spin again..... LOL
no year car, wow.
but there are 2 codes, one for NAV and one for RADIO
and the answers in your operators guide, , here it is again,
im going for the record here...
short answer, NO YOU cant, you LOST it.
med. answer, have post from guy that guessed 5000 time and won.
long below:
quoted 29 times now:
true for all cars, really all modern cars, 2001 to now. about. read your operator guide) (sadly my jeep has no backup method, max paranoia that)
Quotes:
Aug 04, 2013 | Honda Pilot Cars & Trucks
I have an HP Pavillion dv9700 laptop. When I turn on the laptop I get an error reading that says "a disk error ocurred hit ctrl, alt, delete to restart". I do this and and it recycles back to the...
Do you have the Restoration Disk?
You have corrupted basic Windows files. How? Windows is a funny animal. That, and viruses just drive Windows users crazy.
The Restoration (CD) Disk has the basic Windows files. You can do a Repair.
Start the computer, insert the Restoration Disk in the optical drive. Close the drive tray.
When asked perform a Non-Destructive Installation.
Don't have the Restoration Disk?
Contact HP Support.
The disk/s are free. The shipping and handling is not.
In the US the phone number is 1-800-474-6836
It's $17 for a 5 to 7 day ship, $24 for a 2 to 3 day ship.
Not in the US?
Here is the HP Support Worldwide contact page,
http://welcome.hp.com/country/us/en/wwcontact_us.html
Nov 15, 2010 | HP Pavilion dv9500 dv9600 and dv9700 FF...
Non system disk or disk error
it seems that your hard disk is not getting in to Operating System. All you need is to check your drive thoroughly and reinstall OS....reason could be any thing, may be some virus has deleted system files or your drive may have develop some bad sector...
Nov 23, 2009 | HP Compaq nc6000 Notebook
Computers & Internet Logo
Ekse
Marvin
Marvin
