Question about Icom IC-V82
I don't know the Monitor buttom
What is Monitor buttom
Posted by Kyaw Zay Ya on
James Skok
    New Friend:
  • 8 Answers
This is one of those RTFM circumstances best resolved in person. Short of that, I CAN tel you that the monitor button allows to listen in on one or more channels of your choosing as the operator on the other end engages in conversation on one of those channels chosen by you.
Posted on Jun 02, 2013
Has my integrated video failed on my acer aspire am1100-b1401b?
Make sure your Acer works with a different monitor. Check Device Manager in the Windows Control panel and maybe update the monitor/graphics card driver.
Feb 02, 2018 | Acer Aspire Computers & Internet
I turn on my computer and i don't see anything
Guess what? I don't see it either.
Oh,....that's because you're there, and I'm here, and.............never mind.
(OH, I'm jus jokin'!)
Would be helpful to know the laptop manufacturer name, and model number, though. The name you know, the model number is on the bottom of the laptop.
Diagnose to see what the problem is;
A) Graphics chipset,
Or
B) Video Cable,
Or
C) In the Display Assembly
1) Suggest start with attaching a VGA monitor to the laptop.
Laptop OFF, monitor OFF, attach the VGA cable of a VGA monitor, to the VGA connector on the laptop.
Example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on. By factory default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available,
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Hold the Fn key down, and tap once on the Display Toggle-Over key.
Which key is the Display Toggle-Over key?
Don't know. You didn't state the laptop manufacturer name, and model number.
It is one of the F keys at the top. F1 through F12.
Usually has a monitor symbol on it, and a side arrow.
(Most of the time the F4, F5, F7, or F8 key)
No display on the external VGA monitor?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
Still no? Bad graphics chipset.
Display shows on external VGA monitor? Problem is the Video Cable, or in the Display Assembly.
Post back in a Comment after you have performed this procedure, and also post the manufacturer name, and model number.
If the graphics chipset is good, we'll go on with the diagnoses if you wish.
Regards,
joecoolvette
Jul 14, 2012 | Computers & Internet
Can't install base on acer monitor
I, too, struggled with the same issue; however, after a fairly exhaustive search of the Internet, I came across a review that provided the answer: Attach the base to the monitor as you have been doing, but this time, place both base and monitor on the floor--while the base is still flimsily attached to the monitor--and then push down on the monitor. It will secure itself in place. It may seem like you are going to break it, but you won't. It requires little pressure--far, far less than the way we have heretofore been trying to push or jam the base into the monitor. Again, the key is to place the base and monitor (upright position) on the floor, and gently but forcefully push down on the monitor, using both hands, one astride each corner of the monitor.
Jun 02, 2012 | Acer Computers & Internet
Can you please send me the circuit diagram of LG 17 Inch monitor? I will be very great full to you.. Yesterday my monitor's power supply fuse and related 8 pin IC burned and i do'nt know the...
Seems like FixYa don't like me posting images in the solution box.
I'll send you a link instead. The image is quite small, but as I don't have the shecmatics myself, I had to look it up...I guess you can download it as a .pdf file though.
There you go!
Hope it helps. Good luck!
Jul 26, 2011 | LG Studioworks 700S 17" CRT Monitor
My psp x,o,triangle and square buttoms and select buttom not functioning.what to do please help me?
it's abseloutly a hardware problem . You Just Open It and try to clean the buttons that don't work , if you don't know how , a electronic store may help you fix your buttons
Jun 27, 2011 | Sony Video Game Consoles & Games
I need to update the message on our answering machine but don't know how to do it.....& don't have the user guide any more...
there is usually a buttom labelled OGM (outgoing message) press and hold until it beeps - record and let go of the button whne you have recorded the message
May 09, 2011 | Lands Phones
Dear sir, my ibm e54 monitor shoes the monitor menu buttom display again and again.inspite of pressing the exit buttom
Your monitor might be defected during the manufacturing.Try contacting your dealer or salesperson.Avail free services if the time period hasn't exceeded guarantee.
Feb 15, 2011 | IBM E54 15" CRT Monitor
Icom IC-V82 Logo
32 people viewed this question
Top Icom Boating Experts
Lawrence Oravetz
Harrie
matt
matt
Are you an Icom Boating Expert? Answer questions, earn points and help others
