Question about Yamaha RX-V673 7.2-Channel Network AV Receiver
Dear sirs: I would like to know if Yamaha RX-V673 7.2-Channel Network AV Receiver has an International Warranty. I would like to buy it in the USA, but I live in Brazil. Thanks, Flavio [email protected]
Just send an E-Mail to Yamaha's customer service section. I'm certain they will be able to tell you.
The only other problem you might encounter is if the USA model uses a different mains system to the one in Brazil.
Posted on Jun 01, 2013
SOURCE: yamaha rx-1500 av receiver
some times the speaker cables are touching, double check, I had this with my amp and it kept turning itself off
Posted on Jun 25, 2008
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Posted on Mar 02, 2010
SOURCE: Yamaha RX-550 receiver. Presently, no sound on
This solution helps! I got this unit from a friend and there was no sound from the left channel, and after playing with the input knob, there was sound.
I sprayed alot of electronic cleaner and it worked like magic.
the unit is now in full working mode.
Posted on Mar 22, 2010
SOURCE: Yamaha receiver mdl RX-V367. What
Here are the codes for your Yamaha RX-V367: 733, 663, 732,747, 730, 731, 745, 848, 847, 657, 786, 684, 849, 655, 823, 841, 646, 650, and651.
Step 1:
Press and hold the AUX button until all mode button back lights come on, thenrelease.
Step 2:
Press 2, and then enter the device code corresponding to the equipment (listedabove).
Step 3:
Press the POUND (#) button. If the code entered is valid for the remote, themode light flashes three times. Try using the DISH remote to control the component,if it doesn't work with one code try another.
Although we try and facilitate a one remote solution, wecannot guarantee that our codes with work for all brands and models components.Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Support Representative
Posted on Feb 21, 2011
SOURCE: Need yamaha codes to program into uverse tv ir remote
I have the Yamaha V371 receiver and Uverse code 5167 worked on the BLACK (not grey) Uverse remote
Posted on Jan 02, 2012
