We have checked all the fuses and they are fine.the check lite is on.
SOURCE: Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
SOURCE: FRIDGE WILL NOT IGNITE IN GAS MODE
The part you are looking for is the thermo couple. It senses the heat from the flame and holds the gas valve open. The clicking will try three times and then go into lock out. You then will need to reset on the front of the fridge. When installing the thermo couple do not over tighten.
SOURCE: Dometic RM2652 or RM2852 not working.
There is a factory recall on these refrigerators. Call Dometic 1800-544-4881 and give them your serial number and model number. Going through the same thing right now. On my Fleetwood Gearbox. Hope that helps. Robert
SOURCE: royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
SOURCE: Dometic RM2652 not running
dometic RM2652 will not run on gas... check light does not come on ... can hear the gas valve click
