Rosewill R900J 19" Flat Panel LCD Monitor Logo
Posted on Mar 21, 2009
AOC LCD LM725 monitor - Black Screen
I start my computer and turn it on, and everything looks fine for about a matter of seconds and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another seconds. What's up? plz help me......
jewel banks
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Apr 21, 2009
jewel banks
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
Helped
11713
Points
44
OK WELL DID YOU UNPLUG IT FOR A LIL WHILE? IF NOT DO SO. IF PROBLEM STILL THERE HOOK IT TO A DIFFERENT CPU AFTER ALL IS DONE HIT ME BACK
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
2answers
Problem inAOC LM725 monitor
Maybe one of the volume buttons on the front panel control is randomly shorting. Check it out...
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
AOC LM725 Monitor Problem
Change the monitor and check if the PC works. If it works then the problem is with the monitor, you will have to send it to repair. If not then, the problem should be with the power supply, check whether all the cables is kept intact.
AOC LM725 LCD Monitor
try looking for bloated caps, check all diodes... see if its not shorted/leaking and finally check the power regulator ic if its not shorted! note: some capacitors and diodes are very tiny, you should use a lens with good amount of light...
if it does not help..... well, what the hell? try pouring some gas, then light it up! that should solve the problem, at least it turned on right? hehehehe!
Monitor goes blank less than a second after turning on.
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
1helpful
2answers
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Top Rosewill Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
