Question about Acer Aspire One Netbook 8.9" Notebook
Can not remove sd card from storage expansion slot
New machine . just tried putting card in slot. I see that it has an eject but it wont come out? What's the trick?
Posted by datadog on
Anonymous
  • 35 Answers
Push the card in just a bit until it clicks, then it should release unless it is stuck. Sometimes this happens with new SD cards until they are inserted and ejected a few times.
Posted on Mar 21, 2009
How to remove a sd card from the sd card reader in a 23-b090 All-in-One Desktop
A Micro SD card requires a Adapter, which I'm sure I don't need to tell you. Shut down, unplug, try tweezers, toothpick, etc.
Apr 07, 2013 | Computers & Internet
I took the memory card with all my photos to a shop to have them printed. The machine said the card was empty. I returned home and put the card back in, and a blank screen appeared. My sister has the same...
You may have a defective SD card. Have you tried to put your sisters SD card into your camera? Most cameras have internal storage. Do the cameras work with the SD card removed? Most **** stores sell storage cards. a new card may solve your problem.
Oct 10, 2017 | Panasonic Lumix DMC-FX7 Digital Camera
What memory card should i put in a kodak easyshare c530 camera
Kodak easyshare c530 has SD/MMC card expansion slot. So you can use any SD(secure digital) or MMC(multimedia cards) storage devices.
Sample pics below: bourngenius_20.jpgSD bourngenius_21.jpgmmc
Feb 14, 2011 | Kodak EasyShare C315 Digital Camera
Sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
Jul 12, 2010 | Kingston 4GB Secure Digital High Capacity...
It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have a htc touch phone and i put all my pics on the storage card, and than one day all pics where gone and nowi cant even save my pics to the storage card.. and now there is storage card , and storage...
Why this happens:
If for any reason your phone cannot find the SD card on boot it will create a folder on your Phone's Memory called 'Storage Card' to put the Temp Files, Pictures, Music, etc into. Now as soon as the SD card becomes available, since there is already a folder called 'Storage Card', it is forced to name the "Real" SD Card 'Storage Card 2'.
Solution: Delete the "Storage Card" folder and soft reset. If the phone finds the "Real" SD Card, it will be named 'Storage Card' again. If for some reason it is not found, you might have a corrupt SD Card that needs to be reformatted. This would of course loose all the information on the card, so hopefully this is not the case. Warning: If you have pictures or other files in the 'Storage Card' directory, you will want to move them to 'Storage Card 2' before deleting 'Storage Card'. Use the 'File Explorer' found in your 'Programs' to do this. Good luck!
Aug 27, 2008 | HTC Touch P3450 Smartphone
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Micro SD
What you do is get a micro sd adapter and plug it in try that!
Mar 30, 2007 | SanDisk Sansa e250 MP3 Player
Cannot see any SD card in expansion slot
The first thing to try is a soft reset while the card is inserted.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
Expansion card doesn't stay in.
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Acer Aspire One Netbook 8.9" Notebook Logo
516 people viewed this question
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
