There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
Posted on Jun 04, 2013
SOURCE: a trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
Posted on May 29, 2009
SOURCE: Protherm 100EC boiler not firing up
You likely have a flame sensor problem.
If you can wath the ignition proccess, see if you ever notice a flame. If yes, and it then shuts downm, you have a flame sensor failure, replace the sensor and clean the flame burners and orifices.
If no flame at all, then your ignitor is failing, or you are not gatting gas to the ignitor.
Posted on Aug 25, 2009
SOURCE: combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Posted on Dec 30, 2008
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
the problem was solved on my system by replacing thermostatic valve on shower and putting non return valves on hot and cold feed to shower . the problem was caused by cold water getting into the hot water line through the shower hope this helps
SOURCE: non i;n working boiler
Did you put automatic vent plugs on this boiler?This help stop from having air locks.I would try bleeding the high pipe to see if any air come out.The other thing I would check is the valve that out for the pump to pump water around.
Posted on Mar 17, 2009
Dec 30, 2017 | Water Heaters
Mar 02, 2017 | Water Heaters
Dec 23, 2017 | Whirlpool Water Heaters
May 26, 2012 | Water Heaters
Nov 25, 2017 | Water Heaters
Mar 30, 2017 | Water Heaters
Dec 21, 2009 | Water Heaters
Oct 13, 2009 | Water Heaters
Jan 26, 2021 | Rheem Water Heaters
745 people viewed this question
