Televison & Video Logo
Sony model KV-32FS100 powers up fine then a few seconds into the program it blacks out but the sound still plays and the stand by light blinks 3 -6 times and continues to do this for the remainder of the time its on. Any info will be greatly appreciated.
Posted by andrew on
    Top Expert:
  • Televison & ... Master
  • 76,851 Answers
These blinks to standby LED are fault indications. You have to count them correctly, about how many times do it blinks after one time switch ON. By the number of blinks occurs thus, will give you an idea about which section circuit have the fault. If you wish to get more details about the blinking codes to Sony Tvs, check this link. http://electronicshelponline.blogspot.com/ It has blinking codes details to many brand TVs including many models of Sony sets. In case of Sony TVs, blinking codes to many models will be similar. Check the link sited above, and pull up older posts there by its left side bar.
Posted on May 31, 2013
5 Related Answers
Anonymous
SOURCE: No Video or Sound - Red Stand By Light Blinks 6 Times
My book that i have with my tv says it is time to have it servicedby adealer sorry thats all it says
Posted on Nov 06, 2007
Anonymous
  • 62 Answers
SOURCE: SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Posted on Feb 19, 2008
Anonymous
SOURCE: Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Posted on May 09, 2008
Anonymous
  • 448 Answers
SOURCE: tv picture is going out and standby/timer light blinks
Hi Kevin!
The issue may be related to the projection lamp in the TV and replacement may be required. However, before replacing the projection lamp in the TV, you may perform the troubleshooting steps mentioned below.
Please disconnect all the cables from the TV including the power cable then reconnect them after two minutes. Please make sure that the the power cable from the TV is directly connected to a functional wall outlet. Next, you may try connecting any other video source such as cable box, DVD player, Blu-Ray player, Playstation, etc. If the issue persists then try resetting the TV to the original factory settings.
Please follow the steps mentioned below to reset the TV to the original factory settings:
(i) Turn the TV ON.
(ii) Press and hold the Reset button on the Remote Control supplied with the TV, then press the Power button on the front panel of the TV.
(iii) Next, release the Power button. The TV will turn itself off, then back ON.
(iv) Release the Reset button.
If the issue persists then you may replace the projection lamp in the TV.
Posted on Jul 12, 2009
atelier mj
atelier mj
  • 70 Answers
SOURCE: My Sony KV-36XBR800 will no longer turn on when
7 times mean no horizontal deflection. So check horizontal output an solder of it and associate parts.Often resistor and transfo driver of base of h. output.
Posted on Apr 23, 2010
I have a sony trinitron 35" television model kv-32FS100 chasis BA50. When the television is turned off it takes 2 to 3 weeks to power back on. there is a red light that blinks and stops. what can i do...
there could be 2 issues with your TV one is the lamp and the other one is thew power supply board or if you have a click sound in the back is going to be a ballast issue.
1helpful
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Sony FD Trinitron Wega model KV-34BR800
Sony Wega Triniton KV-32FS100 TV
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Help
That would depend upon the number of blinks and the specific model number. I am guessing that the model number is KV-32FS100. What is the blink count?
Dan
Trinitron kv-32FS100 Black screen periodically, with sound, light blinks 5 times
5 blinks means there is a short in hor.section or the power supply
about 200.00 --- 250.00
Sony kv-32fs100 won't power up
Problem inside the tv, maybe leak parts inside you need repairman tech.
Re: Sony KV-24FS120
your problem in system control ic section related to stand by pin check ckt related to stand by section in remote ic check power to system ic loose coniact in remote or system ic thanks
Top Televison & Video Experts
Marvin
Marvin
