Any temp above 260 will result in err on display
SOURCE: why want my kenmore gas stove w/digital display,
Check to make sure the display is not in Celsius degrees. Change it back to Fahrenheit for accurate reading.
SOURCE: Kitchenaid Superba Gas Range - Oven temperature problem
Thank you!!! I was going CRAZY trying to solve this one. I ran the self-clean last night and when I tried to use the oven tonight, it just kept giving me the ERR message. The manual from Kitchen Aide is useless. Thank you SO VERY MUCH!!!!!
SOURCE: KitchenAid Gas Range Model KGRT:
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
KitchenAid Electric range KESC300HWH8 any oven temp entered over 260 degrees results in err message, default temp is now 177 degrees vs 350.
I have the same problem, let me know if you get an answer.
I am getting the same error.
can't set oven temp higher then 260, wondering if it is celcious vs Fahrenheit.. who has the answer?
Had the same problem. Some how it got set to celsius. Open door, Hold the broil button for 5 sec. Fixed.
