Konica Minolta Printer in error state
The Printer Is In An Error State also appear in more wrong with the all inappropriate printer driver and also need to renew the driver to retaliate problems of this kind. You can handle the best way and deal with the drivers is easier. Then, the driver is easy and more intuitive to recognize with your system and find out the all correct drives. You can access to need about the specific system your computer is running.
Reasons that cause Printer Is In An Error State:-
1. Perhaps the drivers are not installed correctly.
2. Indicate if you have downloaded the drivers and software relating to your printer model.
3. Attachment issues can also be the root of this printer error state issue.
4. BIOSS issue is a very simple factor in giving rise to this daunting issue.
5. Perhaps the wires or USB wires are not attached well.
Just follow the steps which are mention on the blog to fix the Printer Is In An Error State. We give online help for Any problem in printers our Call us on TOLL-FREE NUMBER in our BLOG.
SOURCE: Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
SOURCE: Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
SOURCE: The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Testimonial: "This is exactly what I needed to do to fix this error. I got it fixed a long time ago but this is the correct answer!!!"
