I can not unlock the maps on my Garmin 205W, I keep getting the message: Can't unlock maps
Go to http://www.kickasstorrents.com/garmin-gps-maps-unlocker-keygen-and-all-map-codes-included-t1705038.html , good luck
Posted on Aug 24, 2009
If you purchased the maps from Garmin, contact Garmin for an unlock code.
Posted on Aug 06, 2009
SOURCE: how to register a garmin nuvi 205w
go to: https://my.garmin.com/mygarmin/marketing/register.htm
Posted on Jan 22, 2009
SOURCE: garmin 205w nuvi cannot unlock
Ok so I decided I was going to return this thing tomorrow after hours of frustration, so I decided to get crazy with it and then figured out something that seems to have worked (will probably still exchange it for a Magellan or something other than Garmin though).
It's gonna sound crazy, but I opened up the Garmin drive on my computer (Mac, so not sure how this works on PC), and deleted everything I could see (not hidden files). EVERYTHING.
I then went ran Disk Utility and reformated the "Hard Drive" (on PC I would guess your able to do the same somehow). It still ran after that, but obviously could not find maps (since I just wiped every trace of a map away).
Next step, I ran Garmin Map Manager and transfered map for my state (AZ) (I have the latest map update saved on my computer, so I'm guessing Manager used that). Unplugged from comp, powered up, and voila! I will need to download my voices and vehicles again, but hey at least it's working again.
Posted on Apr 13, 2009
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
The downloaded map file (ex: "Garmin_RMU_CNNANT2010C.exe") contains all of North America, and you must select the correct subsection (ex: "Lower 49 States+PR") that you purchased, which is listed on your Garmin myMaps page (My.Garmin.com).
I am a GPS newbie as well and selected "all of North America" when installing my free nuvi 205 map update. A mistake that's too easy to make, esp. considering Garmin still has very little info about selecting the correct map subsection listed on their support site.
You do NOT need to re-download the huge map file, thankfully, but you must re-install (30+ min) to choose the correct map subsection.
"Bad on
Garmin, IMHO for not making important details like that clear to us new
owners." My thoughts exactly.
Posted on Apr 25, 2009
SOURCE: Nuvi 205W keeps rebooting.
Here is the solution
touch the screen in the right bottom and turn the device on keep the screen pressed. when it asks to reset data select yes
Posted on May 16, 2009
Your unit most likely has a firmware error, which could be due to a corrupt file. To solve it you yourself can try to update the firmware when connecting to the pc, if the unit cannot stay on enough for this to be performed, your unit will have to be sent in to service.
Posted on Jun 02, 2009
