Question about Whirlpool Duet GHW9150P Front Load Washer
Unlock control lock in washing machine, whirlpool, duet
How do I unlock a "control locked" position on my washing machine?
Posted by monica_lafla on
  • sasseycassey Apr 06, 2009
    I just purchased a used Whirlpool Duet and it had the control locked on it. I tried holding the lock button for 3 seconds & nothing happened. Does anyone know how to unlock this so that I can use my washing machine?
Anonymous
    New Friend:
My whirlpool heaavy duty 9Kg is locked so I can't unlock it, I need help please
Posted on Aug 22, 2010
Anonymous
Hold control lock for 3 sec. It will make a sound and the door will unlock.
Posted on Mar 21, 2009
1 Related Answer
Dennis Luis
  • 21 Answers
SOURCE: the control lock is on; on my Whirlpool Duet front load washing machine and I can't get it off
Try unplugging to reset power , to your machine..it might work..
Posted on Oct 02, 2012
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a du code that will not go off and the door is locked.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid won't lock when going to wash.
Door Lock Failure
dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from
extending.
Machine/motor control detects open door lid switch when
attempting to lock.
lid is in a locked state.
Door Unlock Failure F-83
retracting.
unlocked state.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer says du and it wont come on! the door lock keeps clicking like its tring to lock but cant
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Sep 16, 2010 | Whirlpool Washing Machines
MODLE NUMBER WTW6400SW HAS CODE DU AND DI COMING UP WHAT IS IT
Door Unlock Error
If it is a cabrio:
Aug 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer displaying du code with 3 quick beeps
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Du f flashes as code on whirlpooll whasher??
Door Unlock Error
If it is a cabrio:
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code du
Door Unlock Error
If it is a cabrio:
Jul 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
DU is flashing and when I press the Pause/Cancel button this does not clear the problem
Door Unlock Error
If it is a cabrio:
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
4,043 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
