Frigidaire oven model #CFEF312FSB CANT FIND THE FUSES OVEN NOT WORKING
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
SOURCE: bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Posted on Jan 24, 2009
SOURCE: I need to change my oven ignitor and I need a diagram
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Posted on Jul 31, 2009
SOURCE: where are the fuses for the oven broiler on model # 9752834A
naps is asking oven element is not working or starting dosen't light up
Posted on Feb 09, 2010
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Posted on May 31, 2010
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Dec 30, 2013 | Ovens
Mar 11, 2011 | Frigidaire Ovens
Feb 13, 2011 | Ovens
Dec 24, 2010 | Frigidaire Ovens
Nov 26, 2010 | Frigidaire Ovens
Jul 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Dec 30, 2009 | Frigidaire FEB27S5A Electric Single Oven
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Jun 15, 2008 | Frigidaire PLEB27T9DC Electric Double Oven
Dec 15, 2018 | Frigidaire Ovens
102 people viewed this question
