Question about Dell PowerEdge 1600SC Server
Cloned Drive won't boot on Dell 1600SC
I have cloned a bootable hard drive off an IBM Server. It boots fine from the IBM. I'd like to install this drive and have it boot from a Dell 1600SC Server. When I power on the Dell Server with the cloned drive in it but it won't boot. The Intel Boot Agent progresses thru the boot options, and then I get a Media Fail. Swapping the drive back to the IBM Server it boots fine. Any advice?
michehembr
    New Friend:
  • 75 Answers
If you are using an image made from the IBM and it has a different processor and the board specs are different that can cause the drive not to boot it will act like it is then go into a perpetual boot. I would try to re image it again to insure that is ok on the drive also check the board If one is and AMD and the other an Intel then that would be part of the problem.
Posted on Nov 02, 2017
2 Related Answers
Anonymous
  • 17 Answers
SOURCE: Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Posted on Jan 11, 2009
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: I have dell 4600 pe serveri want to install
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Posted on Jul 16, 2010
I cloned a 300GB XP boot drive on a 4GB Dell GX280 to a 500GB HD on a 1GB Dell Dimension 5000, but even in Safe Mode, when I try to start up from the 500GB, I get the 0x7b BSOD...
the 7b is a hard drive controller issue the controller on one computer is not the same as the other. maybe try the ultimate boot cd to clear the problem
Nov 26, 2015 | Dell GX280 Optiplex 2.8GHz Desktop...
On my Sony PCV-RZ26G computer I recently installed a 500GB hard drive. With windows XP installed (SP2 or 3) the system fails to find the drive on a cold start resulting in a "Disk Boot Failure"...
try installing afresh from scratch.....
dont clone
try use a smaller partition for C (say 60 - 80GB)
boot from the XP disk(change boot seq in BIOS to boot from CDROM)
and install fresh copy....
Feb 18, 2011 | Sony VAIO Digital Studio PCV-RZ26G PC...
Cannot boot from Momentus Ultra ATA 160 GN HDD
it can only clone the windows files and folders there is other files located on a hidden system on the hard drive, when you install and new hard drive these file are fixed to the drive. to make a bootable drive you need to install these files from a windows disc then add clone files over the top so these files don't get deleted.
May 27, 2017 | Seagate Momentus 5400.3 Hard Drive
Dell 700m wont boot with new hdd
Hi
Need to know how far it boots, eg past cmos screen, ??Win screen
Also some laptops will only accept hard drives up to certain sizes. Check in the Bios as to whether that size drive is actually supported.
Aug 12, 2009 | Dell Inspiron 700M Notebook
Jan 05, 2009 | Dell PowerEdge 1600SC Server
Notebook doesn't see new hdd
You can try upgrading the BIOS:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=713738&rpn=PSA60U&modelFilter=A60-S166&selCategory=3&selFamily=1073768663&selModel=713738|PSA60U
I don't know that's going to do it for you.
This software will allow you to backup and restore the BIOS, just in case, as well as give you another tool to try cloning the drive itself:
http://ping.windowsdream.com/
Dec 05, 2008 | Toshiba Satellite A60-S166 Notebook
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
Oct 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Computer crash!
Try using the boot disk to boot the system and then enter fdisk /mbr to fix the master boot record. It doesn't destroy any data on a computer. There is a professional data recovery businesses that could probably recover that data - but at a cost. They are expensive and advertise in PC Magazines. Take care because there could be a lot of rip-off merchants in this business. In future, buy two hard drives ans use the free XXCopy from http://www.xxcopy.com/ to clone your system from one drive to the other. A good way to back-up your system is to get a second hard disk of the same or greater capacity, and use the free XXCopy from http://www.xxcopy.com/ to make a clone of your system. If the BIOS allows it, you can then set the BIOS to boot to the alternative drive to run the cloned system, format the drive containing the defective system, clone the cloned system back to the main drive, set the BIOS to boot from the main drive, and you are back in business. You can keep the spare hard disk drive stored in a safe place ready to be reinstalled in an emergency, or to update the cloned system. You install XXCopy according to the instructions that come with it. To clone the C: drive to a D: drive enter the following command in the Start => Run box - xxcopy c:\*.* d:\ /clone It is as simple as that XXCopy will open a DOS window and clone the c: drive to the other drive specified in the command. Read the article on how to use XXCopy to clone a system here - http://www.legge40.freeserve.co.uk/Tips.htm.
Jan 30, 2006 | Apple iPod nano
Dell PowerEdge 1600SC Server Logo
93 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
